L&LD
Part of the Furniture
I would also try/test with WinFi from https://www.helge-keck.com/, but I don't have any Wi-Fi 6E routers to test with yet.
Yes. However, I have not confirmed whether Wireshark has incorporated the related decoders. So the frames could be flagged as malformed.Can this be done with Wireshark or other freely-available software tools?
Have you been able to confirm that it works?This app for Android has support to identify 6GHz bands.
WiFiScanner (open-source) - Apps on Google Play
My router is scheduled to be delivered tomorrow. I'll post a preliminary update with my two AX210s and S21 Ultra as I test it out.Have you been able to confirm that it works?
I'm not sure if it's available for iOS.
I would also try/test with WinFi from https://www.helge-keck.com/, but I don't have any Wi-Fi 6E routers to test with yet.![]()
They are roughly 30ft apart , 3 walls in between, same floor.As the (most likely) only 2x Wi-Fi 6E routers in your part of the world, I would say Auto will work okay for a while.
If you're into testing, what can you throw back-and-forth between the two routers to test if Auto or another Control Channel works better?
Nice PHY rates, BTW. How far apart are these routers? Line of sight, or obstacles in between them too?
I have a backup nighthawk if it gets crazy but I don't mind beta testing, the wifi 6 has been bug free just the"e" that seems bugged. Did a factory reset this morning and so far it has been much more stable today. I just can't figure out why my s21 ultra won't go past 350 I'm really thinking its a samsung thing.Wi-Fi 6E, see you in September...
I'm very happy with my Intel AΧ210 Wi-Fi adaptor for my laptop. Wi-Fi is obviously faster (and more consistent) with the RT-AΧ86U vs. the AX200 card it replaced, and even the computer is faster to settle after booting up too (didn't expect that, tbh).
The '6E' router though is still a long way off from being considered. I don't even know about one that may get RMerlin support yet.
I'm sure the current ones will become 'worth it' eventually too. Thanks for all the beta testers that can sort things out for the rest of us and for those, like myself, that don't have the budgets to just sit on a router until it can be made to work as it should too.
I believe you are who I replied to at XDA, but my S21U has no problem nearly maxing out my internet connection via WiFi 6 connected to my RT-AX86. I just checked, I do get slightly better speedtest results on my hardwired laptop (about 480Mbps), but I also have the RT-AX86 set to only 40Mhz.I just can't figure out why my s21 ultra won't go past 350 I'm really thinking its a samsung thing.
Edit: Solved it finally, did a network reset on the s21 and I am now getting 1 gig download on 6eI believe you are who I replied to at XDA, but my S21U has no problem nearly maxing out my internet connection via WiFi 6 connected to my RT-AX86. I just checked, I do get slightly better speedtest results on my hardwired laptop (about 480Mbps), but I also have the RT-AX86 set to only 40Mhz.
That is because the inventory were sold out so Amazon removed the listing, it should come back soon but may dispear again because of hot selling.The fact that Amazon has removed the router from its search results should tell you something.
Did you guys really expect a fully functioning router given past experience with first-in-category products?
Welcome To SNBForums
