GT-AXE11000 security breach or router glitch
JimmyB7
I have the GT-AXE11000, previously had the GT-AX11000. I got the AXE11000 for the WiFi 6E. I have a WiFi 6E adapter on my PC. Useless for now. Waiting on the Windows 10, 21H1, to hopefully finally get to see real 6E. If I stand about 6 feet away with my Samsung Galaxy S21 Ultra lights up with 6E. 6 feet is not very encouraging.
Regardless, I had a major issue with the AXE11000 today. Got up this morning and none of my 30 or so Wi-fi devices were working. I have the three unit ZenWifi AX Mini AiMesh that was working well before using Dual-band Smart Connect (2.4 GHZ and 5 GHZ). I hope to switch this mesh out to 6E someday.
In any event, all my WiFi devices, including mesh, were dead. After poking around I found the SSID network name had changed from ASUS24 to ASUS_5. And here’s the clincher, all the WiFi WPA Pre-Shared Key passwords had been changed. I changed everything back to my original setup and everything came back on line. I had what I thought was adequate password 16 character, upper, lower cases, etc. Passwords only a couple weeks old. I have the latest AiMesh and router firmware.
My question is, do I have a security breach? Or did the router go crazy with a glitch? I suspect security breach. However, the “May 5” security log, example: “May 5 01:05:10 kernel: Doorbell Post Wakeup register : phy_addr: 0xd0802160, virt_addr: ffffff8002652160” is also router suspicious. I’ve enclosed the log that lists happenings up to when I rebooted and switched back the SSID and passwords. (Notice May 5 change to Mar 20) Sorry for the long entry. Thanks in advance.
May 5 01:05:10 kernel: Doorbell Complete Wakeup register : phy_addr: 0xd0802164, virt_addr: ffffff8002652164
May 5 01:05:10 kernel: Doorbell ISR : ffffffbffcf8cab0
May 5 01:05:10 kernel: Doorbell CTX : ffffffc03298d400
May 5 01:05:10 kernel: flow_ring_format : 1
May 5 01:05:10 kernel: idma_active : 1
May 5 01:05:10 kernel: Creating CPU ring for queue number 1 with 128 packets descriptor=0xffffffbffc303008, size_of_entry 16
May 5 01:05:10 kernel: Done initializing Ring 1 Base=0xffffff80003e4000 End=0xffffff80003e4800 calculated entries= 128 RDD Base=3e013000K descriptor=0xffffffbffc303008
May 5 01:05:10 kernel: ^[[0;33;40mRunner DHD Offload initialization complete^[[0m
May 5 01:05:10 kernel: CUR_ETHERADDR : 6
May 5 01:05:10 kernel: f0 2f 74 7c 85 54
May 5 01:05:10 kernel: Dongle Host Driver, version 17.10.157.2803 (r795020)
May 5 01:05:10 kernel: Compiled in drivers/net/wireless/bcmdhd
May 5 01:05:10 kernel: wfd_registerdevice Successfully registered dev eth7 ifidx 0 wfd_idx 1
May 5 01:05:10 kernel: Register interface [eth7] MAC: f0:2f:74:7c:85:54
May 5 01:05:10 kernel: PCI_PROBE: bus 1, slot 0,vendor 14E4, device AAA4(good PCI location)
May 5 01:05:10 kernel: dor2: runner supported ring format types TxP 0x5, RxP 0x3 TxC 0x3 RxC 0x3^M
May 5 01:05:10 kernel: dhd_runner_attach: Tx Offload - Enabled, Ring Size = 1024
May 5 01:05:10 kernel: dhd_runner_attach: Rx Offload - Enabled, Ring Size = 1024
May 5 01:05:10 kernel: TX wakeup info: reg = <0x82299004>, val = <0x12000000>
May 5 01:05:10 kernel: RX wakeup info: reg = <0x8229a004>, val = <0x2a000000>
May 5 01:05:10 kernel: dhd_attach(): thread:dhd_watchdog_thread:2f9 started
May 5 01:05:10 kernel: ^[[0;31mwfd_bind: wfd2-thrd initialized pktlists: radio 2 nodes 1032 xfer dhd_pktfwd_xfer_callback+0x0/0x798 [dhd]
May 5 01:05:10 kernel: ^[[0m
May 5 01:05:10 kernel: Creating CPU ring for queue number 4 with 1024 packets descriptor=0xffffffbffc5c03c0
May 5 01:05:10 kernel: Creating CPU ring for queue number 5 with 1024 packets descriptor=0xffffffbffc5c0400
May 5 01:05:10 kernel: ^[[1m^[[34m wfd_bind: Dev eth%d wfd_idx 2 wl_radio_idx 2 Type fkb:sll configured WFD thread wfd2-thrd minQId/maxQId (12/13), status (0) qmask 0x30^[[0m
May 5 01:05:10 kernel: Instantiating WFD 2 thread
May 5 01:05:10 kernel: ^[[0;32mdhd_wfd_bind: wl2 wfd_idx 2 success^[[0m
May 5 01:05:10 kernel: dor2: MSG Ring format set to 1
May 5 01:05:10 kernel: dhd_runner_flowmgr_init: dhd2_rnr bootmem addr<ffffffc009300000> size<11534336>
May 5 01:05:10 kernel: dhd_runner_profile_init: profile = 3 1024/0512 2048/1024 1024/0512 0512/0512 0512/0512
May 5 01:05:10 kernel: ^[[0;33;40mRunner DHD PCIE: vendor<0x14e4> device<0xaaa4> bus<1> slot<0>^[[0m
May 5 01:05:10 kernel: Initial configuration
May 5 01:05:10 kernel: =================================
May 5 01:05:10 kernel: rx_post_flow_ring_base_addr : ffffffc02d40a000
May 5 01:05:10 kernel: tx_post_flow_ring_base_addr : ffffffc0092d8000
May 5 01:05:10 kernel: rx_complete_flow_ring_base_addr : ffffffc02d55e000
May 5 01:05:10 kernel: tx_complete_flow_ring_base_addr : ffffffc02fc6e000
May 5 01:05:10 kernel: r2d_wr_arr_base_addr : ffffff8002669000
May 5 01:05:10 kernel: d2r_rd_arr_base_addr : ffffff8002669802
May 5 01:05:10 kernel: r2d_rd_arr_base_addr : ffffff800266a000
May 5 01:05:10 kernel: d2r_wr_arr_base_addr : ffffff8002669c02
May 5 01:05:10 kernel: tx_post_mgmt_arr_base_addr : ffffff800266a800
May 5 01:05:10 kernel: tx_post_mgmt_arr_base_phys_addr : 0x2d5a9800
May 5 01:05:10 kernel: r2d_wr_arr_base_phys_addr : 0x2d5a8000
May 5 01:05:10 kernel: d2r_rd_arr_base_phys_addr : 0x2d5a8802
May 5 01:05:10 kernel: r2d_rd_arr_base_phys_addr : 0x2d5a9000
May 5 01:05:10 kernel: d2r_wr_arr_base_phys_addr : 0x2d5a8c02
May 5 01:05:10 kernel: Doorbell Post Wakeup register : phy_addr: 0xc0802160, virt_addr: ffffff8002662160
May 5 01:05:10 kernel: Doorbell Complete Wakeup register : phy_addr: 0xc0802164, virt_addr: ffffff8002662164
May 5 01:05:10 kernel: Doorbell CTX : ffffffc02db0c400
May 5 01:05:10 kernel: Creating CPU ring for queue number 2 with 128 packets descriptor=0xffffffbffc303090, size_of_entry 16
May 5 01:05:10 kernel: Done initializing Ring 2 Base=0xffffff80003e8000 End=0xffffff80003e8800 calculated entries= 128 RDD Base=3e017000K descriptor=0xffffffbffc303090
May 5 01:05:10 kernel: f0 2f 74 7c 85 58
May 5 01:05:10 kernel: wfd_registerdevice Successfully registered dev eth8 ifidx 0 wfd_idx 2
May 5 01:05:10 kernel: Register interface [eth8] MAC: f0:2f:74:7c:85:58
May 5 01:05:10 kernel: random: init urandom read with 17 bits of entropy available
May 5 01:05:10 kernel: proc_dostring_crashlogsave: crash log filename is /jffs/crashlog.log
May 5 01:05:10 kernel: crashFileSet: log signature invalid !
May 5 01:05:10 kernel: ret 0 retlen 65536 buff <6>IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
May 5 01:05:10 kernel: FPM Pool 0: invalid token 0x00798000 freed
May 5 01:05:10 kernel: FPM Pool 1: invalid token 0x206d8000 freed
May 5 01:05:10 kernel: Interface eth%d doesn't exist
May 5 01:05:10 kernel: could not find igs interface!
May 5 01:05:10 kernel: IGMP Query send failed
May 5 01:05:23 ntp: start NTP update
Mar 20 07:49:15 rc_service: ntp 2058:notify_rc restart_diskmon
Mar 20 07:49:15 disk_monitor: Finish
Mar 20 07:49:15 disk monitor: be idle
Mar 20 07:49:16 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:7c:85:50:00:01:5c:69:22:46:08:00 SRC=52.114.132.32 DST=174.96.79.209 LEN=111 TOS=0x00 PREC=0x00 TTL=107 ID=20169 DF PROTO=TCP SPT=443 DPT=55351 SEQ=2766833297 ACK=2178141068 WINDOW=2049 RES=0x00 ACK PSH URGP=0 MARK=0x8000000
Mar 20 07:49:17 cfg_server: event: wl_chanspec_changed_action
Mar 20 07:49:17 cfg_server: skip event due no re
Mar 20 07:49:17 kernel: DROP IN=eth0 OUT= MAC=f0:2f:74:7c:85:50:00:01:5c:69:22:46:08:00 SRC=52.114.132.32 DST=174.96.79.209 LEN=111 TOS=0x00 PREC=0x00 TTL=107 ID=20170 DF PROTO=TCP SPT=443 DPT=55351 SEQ=2766833297 ACK=2178141068 WINDOW=2049 RES=0x00 ACK PSH URGP=0 MARK=0x8000000
Mar 20 07:49:18 cfg_server: event: wl_chanspec_changed_action
Mar 20 07:49:18 cfg_server: current chansp(unit0) is 1007
Mar 20 07:49:18 cfg_server: current chansp(unit1) is e09b
Mar 20 07:49:18 BONDING: option disabled
