Gt-axe16000 Guest is active, but the GUI says is disable. Why
porfavorhelp
1st wifi network configure with 4 band with one SSID and smart connect active with wpa2/wpa3. Guest configured with one 2.4 band only with wpa2, but the GUI says is disable plus some device are going randomly Offline too. Can any body help me please?
Yes i have the same with the axe16000.
Guest network works fine but no icon in gui saying its enabled.
I gave all my devices who use the guest network a manual/static ip,this made the connections more stable ,less offline/online that is.
Using the second guest network btw...
