I just set up a GT-BE98 Pro a few days ago and my problem is that it has been dropping all of its clients and not letting them rejoin on the 2.4g band.
I was on the most recent firmware for a while but reverted to 3.0.0.6.102_32882, unsure if the Guest Network Pro IoT network was adding to the problem.
When I did this I also did a factory reset after it.
So far the 5g and 6g bands work without issue.
The few settings I have modified:
I have been struggling with this issue for a few days now looking for solutions but nothing has worked so far.
I have also attached my system Log.
I have looked through but don't see anything obvious to fix.
I All I see is when it starts to kick all of its clients but I can't figure out the cause.
Thanks for any advice!
Screenshot off WIreless General 2.4
Screenshot of my 2.4 Professional Tab:
- LAN: Changed the LAN IP address from the default to the one I was using with my old router.
- Switch Control: Jumbo Frame: Enabled
- DCHP Server: Manually Assigned one IP address
- Administration: Turned off auto firmware upgrade
- Screenshots of Wireless info for 2.4 band is shown below
- WAN:
- Internet Connection Disabled UPnP
- Virtual Server / Port Forwarding: Added three port forwards
