Hello everyone,
Yesterday I upgraded from 32882 to 34491 everything worked great except for my Arlo Video Doorbell. I have 21 wifi devices with most of it being IoT. I did everything I could with Arlo to get the bell from talking with the router but it never worked. After spending 5h to debug this, including time spent with their support, Ibreverted back to the 32882 firmware and it worked again. Something changed in there that prevents the Arlo VDB to work. Does the 34491 increased the security which the DB doesn’t support, or Arlo needs to update their VDB firmware updated to work with the new 34491, or maybe some of you figured it out and there is a specific setting in the BE98 Pro that needs to change for compatibility that I’m not aware? The Arlo VDB only works on 2.4Ghz. Maybe some of you are experiencing similar issues with other devices… I have another device that didn’t connect anymore as with the 34491 it was showing 19 devices vs 21 with the old one, but didn’t take the time to find which one of it as I had spent enough time working on my DB before reverting back to the old firmware.
Thanks for any feedback in advance!
