YazFi Guest Network with YazFi assigning LAN IPs, not the IPs of my guest settings.
So my current plan is to not use a guest network, and have DHCP reservations for my IoT devices so they always get the same IP. I am doing some preliminary testing with IPtables and I'm having no luck.
Just to test if I could use IPtables to block a client from accessing other devices on the LAN, I assigned my Mac an IP of 192.168.50.199.
I SSH'd into the router and issued the following command:
iptables -I FORWARD -s 192.168.50.199 -d 192.168.50.0/24 -j DROP
This should drop packets from my mac when I ping other devices on the LAN.
I ran #iptables -L -n
jorg@RT-AX88U-F610:/tmp/home/root# iptables -L -n
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
INPUT_PING  icmp --  0.0.0.0/0            0.0.0.0/0            icmptype 8
ACCEPT     all  --  0.0.0.0/0            0.0.0.0/0            state RELATED,ESTABLISHED
logdrop    all  --  0.0.0.0/0            0.0.0.0/0            state INVALID
PTCSRVWAN  all  --  0.0.0.0/0            0.0.0.0/0
PTCSRVLAN  all  --  0.0.0.0/0            0.0.0.0/0
logdrop    tcp  --  0.0.0.0/0            0.0.0.0/0            tcp dpt:5152
ACCEPT     all  --  0.0.0.0/0            0.0.0.0/0            state NEW
ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0            udp spt:67 dpt:68
INPUT_ICMP  icmp --  0.0.0.0/0            0.0.0.0/0
ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0            udp dpt:53
ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0            udp dpt:67
ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0            udp dpt:68
DROP       all  --  0.0.0.0/0            0.0.0.0/0
WGSI       all  --  0.0.0.0/0            0.0.0.0/0
WGCI       all  --  0.0.0.0/0            0.0.0.0/0
OVPNSI     all  --  0.0.0.0/0            0.0.0.0/0
OVPNCI     all  --  0.0.0.0/0            0.0.0.0/0
Chain FORWARD (policy ACCEPT)
DROP       all  --  192.168.50.199       192.168.50.0/24
IPSEC_DROP_SUBNET_ICMP  all  --  0.0.0.0/0            0.0.0.0/0
IPSEC_STRONGSWAN  all  --  0.0.0.0/0            0.0.0.0/0
WGSF       all  --  0.0.0.0/0            0.0.0.0/0
OVPNSF     all  --  0.0.0.0/0            0.0.0.0/0
WGNPControls  all  --  0.0.0.0/0            0.0.0.0/0
SECURITY   all  --  0.0.0.0/0            0.0.0.0/0
ACCEPT     all  --  0.0.0.0/0            0.0.0.0/0            ctstate DNAT
DNSFILTER_DOT  tcp  --  0.0.0.0/0            0.0.0.0/0            tcp dpt:853
WGCF       all  --  0.0.0.0/0            0.0.0.0/0
OVPNCF     all  --  0.0.0.0/0            0.0.0.0/0
Chain OUTPUT (policy ACCEPT)
OUTPUT_DNS  udp  --  0.0.0.0/0            0.0.0.0/0            udp dpt:53 u32 "0x0>>0x16&0x3c@0x8>>0xf&0x1=0x0"
OUTPUT_DNS  tcp  --  0.0.0.0/0            0.0.0.0/0            tcp dpt:53 u32 "0x0>>0x16&0x3c@0xc>>0x1a&0x3c@0x8>>0xf&0x1=0x0"
OUTPUT_IP  all  --  0.0.0.0/0            0.0.0.0/0
You can see the first rule in the FORWARD chain should drop all packets from 192.168.50.199 to other clients on 192.168.50.0/24
If I ping a device from the mac, I still get replies.
 % ifconfig
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
        options=400<CHANNEL_IO>
        ether b8:f6:b1:17:67:2b
        inet 192.168.50.199 netmask 0xffffff00 broadcast 192.168.50.255
        media: autoselect
        status: active
~ % ping 192.168.50.3
PING 192.168.50.3 (192.168.50.3): 56 data bytes
64 bytes from 192.168.50.3: icmp_seq=0 ttl=64 time=3.637 ms
64 bytes from 192.168.50.3: icmp_seq=1 ttl=64 time=4.444 ms
64 bytes from 192.168.50.3: icmp_seq=2 ttl=64 time=3.726 ms
^C
--- 192.168.50.3 ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 3.637/3.936/4.444/0.361 ms
I tried restarting skynet but that just overwrites the rules. If I can figure out how to get the rules even working I will try my hand at adding them to a script to make them persistent.
