netware5
I don't have Entware, Optware, or anything else other than the Merlin FW. Here's what a positive result looks like.
Very strange .... What service is listening on your router's WAN port 443?
I don't know. I haven't customized any of my ports. Isn't that the standard HTTPS port?
I rebooted the router and got a happier result. Odd.
Yes, this is the standard HTTPS port, but your router's GUI default WAN port should be 8443. Did you checked the box "Enable Web access from WAN" under "Administration>System" menu? Or may be you have some device on your LAN that is listening on 443 and the port is forwarded under "WAN>Virtual Server/Port Forwarding" menu? Or your firewall is disabled?
443 is used by AiCloud.
Oh yesas I am not using AiCloud I forgot about this possibility
But in any case this should not happen as the router's OpenSSL library version is less than 1.0.1.
None of the above on my N66U. It's almost as if some process started listening on 443 since the prior reboot. For future reference, what command would I run to see what's listening on a particular port?
Merlin, BTW today the OpenVPN team has released OpenVPN 2.3.3. Do you plan to incorporate it within the next version of your FW?
When I initially set up the OpenVPN client I had to use 2.2.2 because I was never able to get 2.3 to work. I just ran an "openssl version" command and it returned 1.0.0e so I believe this client is safe. Can anyone confirm? Thanks.
Thread starter | Title | Forum | Replies | Date |
J | AC-86u vulnerability tracking post-EoL (asuswrt-merlin 386.14_2) | Asuswrt-Merlin | 8 |
Welcome To SNBForums
