K-2SO
Please, next time you get hacked post a screenshot of what your concern is as @ColinTaylor suggested above.
Sounds like you browsed something dodgy on the pc and it became infected and now the router is detecting it as infected under ai protection.
Can I offer my opinion as an IT professional?
This means the pc, your browsing habits and to be honest the very poor AV product installed are the likely problem.
Rootkit viruses tend to install themselves into a hidden boot partition on the hard drive. You'll need to manually remove all partitions before reinstalling windows from scratch.
Then get a good quality antivirus product installed if you're browsing suspect content. Mcafee is pretty poor to be perfectly honest. I'd get Sophos, Norton or Bitdefender installed. Most of these AV products also have a root kit removal tool if required as well.
Better still set up a hyper-V vm in Windows once you have the pc back up and running. Make sure the AV is installed on it, set it with a static IP and make sure your router sends all it's traffic over a reputable vpn service. Take a snapshot of the vm whilst it is clean. Then do all your dodgy browsing, torrenting etc through the vm. If it gets infected revert to the snapshot which will instantly clean it up again. This way there is no risk to your physical pc.
I believe you hacked me good with the first post. I need some time to adjust my eyes now.![]()
Welcome To SNBForums
