fivedollarmilkshake
Good day everyone.
I mistakenly uploaded shibby arm trx to my ac66. Now router dows not respond on lan, asus restoration utility does not work (pc set 192.168.1.2/255.255.255.0), tftp just dows not start so i can't upload anything. Bought serial cable. and it shows this:
Decompressing...done
CFE version 6.30.39.29 (r338244) based on BBP 1.0.37 for BCM947XX (32bit,SP,LE)
Build Date: 一 10月 15 10:41:41 CST 2012 (yau@wireless-pub2)
Copyright (C) 2000-2008 Broadcom Corporation.
Init Arena
Init Devs.
Boot partition size = 262144(0x40000)
Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Found a AMD NAND flash with 2048B pages or 128KB blocks; total size 128MB
bcm_robo_enable_switch: EEE is disabled
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.39.29 (r338244)
CPU type 0x19749: 600MHz
Tot mem: 131072 KBytes
CFE mem: 0x80700000 - 0x8094EDE0 (2420192)
Data: 0x80738B70 - 0x8073BE10 (12960)
BSS: 0x8073BE10 - 0x8074CDE0 (69584)
Heap: 0x8074CDE0 - 0x8094CDE0 (2097152)
Stack: 0x8094CDE0 - 0x8094EDE0 (8192)
Text: 0x80700000 - 0x80738B70 (232304)
Committing NVRAM...done
Device eth0: hwaddr 08-60-6E-XX-XX-XX, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Null Rescue Flag.
boot the image...
Check 2 trx result: 0, 0
go load
Loader:raw Filesys:tftp Dev:eth0 File:: Optionsnull)
Loading: TFTP Server.
Failed.
Could not load :: Timeout occured
Loader:raw Filesys:raw Dev:nflash0.os File: Optionsnull)
Loading: ....... 4144640 bytes read
Entry at 0x80001000
Closing network.
Starting program at 0x80001000
Show devices command:
CFE> show devices
Device Name Description
uart0 NS16550 UART at 0x18000300
uart1 NS16550 UART at 0x18000400
flash0 ST Serial flash size 2048KB
flash0.boot ST Serial flash offset 00000000 size 256KB
flash0.trx ST Serial flash offset 00040000 size 1KB
flash0.os ST Serial flash offset 0004001C size 1728KB
flash0.nvram ST Serial flash offset 001F0000 size 64KB
flash1.boot ST Serial flash offset 00000000 size 256KB
flash1.trx ST Serial flash offset 00040000 size 1728KB
flash1.nvram ST Serial flash offset 001F0000 size 64KB
nflash0.trx Unknown type 146 NAND flash offset 00000000 size 1KB
nflash0.os Unknown type 146 NAND flash offset 0000001C size 131072KB
nflash1.trx Unknown type 146 NAND flash offset 00000000 size 32768KB
nflash1.brcmnand Unknown type 146 NAND flash offset 02000000 size 98304KB
nflash2.prefix Unknown type 146 NAND flash offset 00000000 size 65536KB
nflash2.trx Unknown type 146 NAND flash offset 04000000 size 32768KB
eth0 Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller
*** command status = 0
CFE>
If anyone knows how to bring it back to life, please tell me. Thank you in advance.
Init Arena
Init Devs.
Null Rescue Flag.
boot the image...
go load
Failed.
Entry at 0x80001000
Closing network.
CFE> show devices
CFE>
