TL;DR: router configuration changes, new Wifi device connection to router, etc...seems to kill the router's connection to the WAN. ???
I'm having a new issue with my RT-AC68U which i've owned for years. What initially happened is all my devices (wired and wireless) lost network connectivity. After some testing and troubleshooting: the ISP's (Spectrum) router appears to be OK; I can plug a PC into the modem and it works perfectly fine. The ASUS router was indicating the following error: "Your ISP DHCP is not functioning properly". It also might be important to note that ~1 day prior to this: Spectrum had an outage in my area for a few hours. Everythign worked fine for about 1 day after they restored service (it was not specific to me...was an area outage).
I started debugging with the ISP and they sent a re-provisioning command to the modem. This didn't help, so I tried to connect a PC wired directly to the modem. This worked fine so I focused on the ASUS router. I've performed multiple full factory resets of the ASUS as well as ensured I was on the latest firmware (3.0.0.4.386_43129 which is ~May 2021). I have set the DHCP Query Frequency to Normal (I read an old post which said that the Aggressive mode can sometimes cause problems, but I've never had issues with this for years). I would occasionally get the router to work for short periods but it would drop WAN. I performed some specific testing to highlight when/what causes the ASUS to lose WAN. My steps are commented ### in-line with the ASUS router log.
### STARTING STATE: Modem OK (verified with direct PC->Modem connection). Factory reset ASUS router, configure main WIFI and Admin credentials, verifiy wired connection thru ASUS has network access for aboug 1hr ###
Jun 9 10:34:28 acsd: selected channel spec: 0x1009 (9)
Jun 9 10:34:28 acsd: Adjusted channel spec: 0x1009 (9)
Jun 9 10:34:28 acsd: acs_set_chspec: 0x1009 (9) for reason APCS_CSTIMER
Jun 9 10:34:31 acsd: selected channel spec: 0xe29b (157/80)
Jun 9 10:34:31 acsd: Adjusted channel spec: 0xe29b (157/80)
Jun 9 10:34:31 acsd: acs_set_chspec: 0xe29b (157/80) for reason APCS_CSTIMER
Jun 9 10:49:33 acsd: selected channel spec: 0x1008 (8)
Jun 9 10:49:33 acsd: Adjusted channel spec: 0x1008 (8)
Jun 9 10:49:33 acsd: acs_set_chspec: 0x1008 (8) for reason APCS_CSTIMER
Jun 9 10:49:35 acsd: selected channel spec: 0xe29b (157/80)
Jun 9 10:49:35 acsd: Adjusted channel spec: 0xe29b (157/80)
Jun 9 10:49:35 acsd: acs_set_chspec: 0xe29b (157/80) for reason APCS_CSTIMER
Jun 9 11:00:47 disk_monitor: Got SIGALRM...
Jun 9 11:34:44 acsd: selected channel spec: 0x1008 (8)
Jun 9 11:34:44 acsd: Adjusted channel spec: 0x1008 (8)
Jun 9 11:34:44 acsd: acs_set_chspec: 0x1008 (8) for reason APCS_CSTIMER
Jun 9 11:34:46 acsd: selected channel spec: 0xe22a (44/80)
Jun 9 11:34:46 acsd: Adjusted channel spec: 0xe22a (44/80)
Jun 9 11:34:46 acsd: acs_set_chspec: 0xe22a (44/80) for reason APCS_CSTIMER
(to be continued due to length)
