I recently purchased the Asus PCE-AC68 WiFi adapter and RT-AC68 router thinking the WiFi AC speeds would be at least double those of my exiting 2.4GHz network. That did not pan out. I'm experiencing OK performance on the 2.4GHz side but on the 5GHz side the performance is brutal.
Symptoms on the 5GHz band:
I have my computer sitting directly next to the router
Computer shows the link at it's highest ratting of 1300mbps
Computer shows the signal strength at a strong -30db
So far so good,
Now I try to transfer a large file from my PC to my NAS (which is wired to the router), the throughput fluctuates between 2MB/s and 20MB/s, I was expecting a consistant throughput of at least 40MB/s like most of the reviews show.
When i hard wire my computer to the router I can write to the NAS at 50MB/s.
When I connect to my network on the 2.4GHz band I get a constant 18MB/s write speed to the NAS.
Transfer speeds:
Computer ----- cat5e ------ router ------ cat5e ------ NAS = 50 MB/s
Computer ----- 2.4GHz ------ router ------ cat5e ------ NAS = 18 MB/s
Computer ----- 5.1GHz------ router ------ cat5e ------ NAS = fluctuating between 2 and 20 MB/s
So the 2.4GHz side is fine,
Distance and line of sight are not a problem,
I've replaced the WiFi card once already,
My router is AC compatible,
I've tried the wifi card in different PCI slots,
I've tried the stock and Merlin FW on the router,
Help diagnosing the issue is welcome!
The transfer graphs look like this:
So far so good,
Transfer speeds:
