mindbender9
Hello all,
Situation:
I purchased a 1 TB Hammer MyShare NAS *almost* a year ago and for some reason, the unit refuses to power on as of last night. The LED on the power adaptor brick is flashing on/off when I plug it into the NAS but is strangely solid green when it is removed.
Anyhow, I contacted Hammer's Tech Support and the tech is going to send a replacement cord out today for me to try. The problem is that I don't think that a new cord will fix things and the unit itself is bad.
My problem is that if I send it back for warranty coverage, Hammer's tech support will only send me a new unit and I lose all my data. The tech support rep said that my only other choice is to break the warranty seal and pull the drives out and have someone extract the data. Although $500 would go down the drain, I would still be able to keep all of my files (which is probably what I'm going to do).
Specifics:
Long story short, I had the NAS set up in a RAID1 configuration where data is mirrored on both drives. I've heard that you cannot simply plug a mirrored drive in and copy the data off to your PC. I'm afraid that there is a way to salvage the data with some specialized software but I don't know what to do.
Can someone help with this? The Hammer tech support cannot advise me how to do this (because it voids the warranty), and all they could say is that I have to take it to "someone who knows how to do this."
Help!
Please help! Oh, and I would avoid the Hammer product line if a NAS manufacturer cannot assist a customer in salvaging data on one of their units.
Thank you for your help!
Situation:
Specifics:
Help!
