HELP! How to salvage data from a failed RAID1 setup (Hammer MyShare)
You were lucky this time, vfreak. A NAS can fail in a way that will corrupt the drive data.
Never trust your data to a single device. And if you have reason to believe that a device that you are using is flaky, replace it.
Update - 12/29/2010
It's been a while since I last updated this thread, but I figured I should mention a couple of things that have occurred since the last time.
- First, don't buy a Hammer NAS unit. I know that I've grumbled about them in the past, but I still stand by that. Their customer service policies are less than ideal based on my experiences with them.
- A few months ago, I suffered a brief power surge that knocked power out to my equipment for a second or two. And of course, that was all that was needed for the Hammer NAS to be affected. Long story short, the NAS ate it and lost the RAID 1 array.
While I had some of the data backed up, I (of course) didn't get everything saved and it came back to haunt me. Again.
The NAS unit was able to power on eventually, but I was unable to access the web interface of the unit. Replacing the drives with temporary units revealed that the NAS' built-in web server was damaged (e.g. html failures, missing links, etc.).
Long story short, I was left with a nearly-dead NAS chassis and two RAID 1 drives in a questionable state.
- Yesterday, I came across a forum post about TestDisk (http://www.cgsecurity.org/wiki/TestDisk) and how the user was able to recover data from his damaged RAID 1 array (ext3).
I gave it a try and ran it off an Ubuntu box and TestDisk was able to analyze/detect the partitions on one of the RAID 1 drives. Specifically, I had to look at one of the RAID partitions (not the md0/md1 areas) and perform a "Deeper Search" with the application.
When TestDisk saw the RAID partition, I entered "P" to list the files (if available). Sure enough, the data directories came up with only a few marked as damaged. I noticed that one of the options was "c" to copy files from the partition, which I was able to transfer to the local Ubuntu hard drive. I was able to retrieve 90% of my partition (undamaged) and will be looking to transfer nearly all of the remaining data soon.
If you're having issues with an inaccessible partition (but on a functioning drive), you might want to give TestDisk a try. Be advised that while it is free, it is command-line based and requires Admin rights. It is available on many platforms (Win, OSX, *nix) as well.
Please note that I do not have anything to do with TestDisk's developer, but I am a grateful user. I'll probably send him a donation for this, which he clearly deserves.
And thanks to Tim and the other users here who have made life a little easier when hardware fails us.
Thanks for the post mindbender9. Hope it helps someone. Now get yer NAS backed up, willya?
Hammer's Personal Storage Manager (PSM)application
Hopping that you will be able to help me. :confused:
Got HAMMER STORAGE unit a some time ago ...
Unit is in perfect condition, however my desktop dead. So, I rebuild it.
But the problem is - I lost software CD for NAS storage.
All I need: copy of that soft (Hammer's Personal Storage Manager
(PSM)application).
So, can you ZIP it and email it to me? Or I can setup ftp account for you
and you will upload it for me.
Your fast reply would be greatly appreciated.
Email: mark18976@gmail.com
