Synology/D-Link/Netgear/Qnap/Patriot, your experience and what buy?
Hello
I want to buy a NAS device to home, prices up to 300€ without HDD, the parameters should be as follows:
-2x (4x) SATA HDD (preferad unlimited capacity)
-separate HDD, example: I put 2x 2TB HDD and I use solo (I am not about safety, but the max storage capacity)
Decide between:
Patriot Valkyrie http://www.patriotmemory.com/products/d ... 26&type=21
D-Link DNS-323 http://www.dlink.com/products/?pid=509
Netgear RND2000 http://www.netgear.co.uk/readynasduo.php
Synology DS-210j http://www.synology.com/enu/products/DS210j/spec.php
Synology DS-209 http://www.synology.com/enu/products/DS209/spec.php
QNAP TS-210 http://www.qnap.com/pro_detail_hardware.asp?p_id=135
Your experience of practical use?
Thank you for answers.
Hello
Decide between:
