hello,
i am on the market for another NAS. i currently have 1.5TB in a dns323, and reached capacity. its used with Win7 and WinXP computers at home.
other than centrally storing my data, i mainly use my NAS to stream content (music, photos, movies), most importantly movies streamed to my PS3. I've funplugged the twonkymedia server on the dns323, and works well. My increasing collection of blu-ray means that media takes up the vast majority of my storage needs. the dns323 can stream HD content just fine, but i will say that fast forwarding or rewinding a HD video does not work well. i guess the throughput or the processor speed of the dns323 can't handle the high throughput required? so, unless its cost prohibitive, i'd like my new NAS to be able to handle fast forwarding of HD movies.
1) should I be looking at the file read/copy performance metrics to evaluate this?
after reviewing the NAS charts on SNB, my impression is that the throughput of the NAS are limiting compared to the hard drives (ie. up to 100Mbps NAS vs 3Gbps HDD). therefore,
2) does it matter if I buy (lower performing) green drives? for ex. will i see a performance gain by using WD caviar blue/black over caviar green? (assuming answer yes to question1)
i *think* i want this new NAS to supplement my existing dns323, however, if it makes more sense to get a bigger 4bay unit to consolidate all my storage and then retire/recycle the dns323, then i'm open to that as well.
my current 1.5TB got filled in about 1.5+years of use. I believe this pace will continue - if I buy a 2TB drive, it will be consumed in about 2+yrs. - makes me think I could get a pair of 2TB drives throw them in a 2bay unit, mirrored ... would last me another 2+ yrs. or config as JBOD would last 4 yrs.
another consideration is the first issue i asked about above - throughput speeds. if i got a 4 bay unit and configured RAID5, is the file read performance gain significant? (again assuming yes to question 1)
3) Supposing I am ok to shop for a new NAS again in ~2+yrs... should I get a 2 bay or 4 bay NAS today?
based on the NAS charts on SNB (particularly price/perf), i have narrowed down to qnap and synology (but still open to suggestions). a slight advantage for qnap since they provide a twonkymedia qpkg plug in. can anyone vouch for synology's DLNA/uPnP streaming to a ps3? the TS-212 seems to be a good candidate (78Mbps), and the TS-219p+ looks even better (94Mbps). but for the cost of the TS-219p+, the TS-412 and the synology DS-411j are within striking distance! decisions decisions. the DS-411j is not reviewed on SNB, so, hard to compare metrics.
in case it may influence decision, on the fly transcoding of mkv's would be a big plus.
so am i on the right track with the listed models? i am kinda leaning towards a 2bay if only to be cost conscious, however, i would rather buy something and be happy with it... looking forward to hearing what you think!
