HELP: sendto: Network is unreachable
djamvl88
Hi. Im trying to configure my home network for along time. Please, help. Googling didn't helps.
I draw simple scheme of my network.
Im try to install entware on my asus rt 66U using this man.
I run entware-setup.sh script, select my hdd drive(ext3 formated), but script can't dowload any files from the repo.
Then I try to ping 8.8.8.8
it says "sendto: Network is unreachable"
Internet via asus work fine, but when I connect to it via ssh and try ping any ip I get this error.
I type in term "route add default gw 192.168.1.1". after that, ping works, but after reboot i have the same problem.
So I think this cause error while installing entware.
Sorry for my bad English.
