I have and asus RT-N66U running merlin which I have openvpn setup via which I turn on my server using the routers WOL once I have the VPN connected, this works flawlessly everytime remotely, however, it seems to time out if the server is not switched on for sometime and having had a read around on this matter I'm drawn to the conclusion that I need to setup a static ARP, unfortunately I have no idea how to do this or even what it really is, when the server is on and I can see it in my client list, if I click it, it tells me that MAC address binding is on but I don't think this the problem, I also read this elsewhere...
So I solved the problem, I have an ASUS router that has an SSH feature that supports wol. So I acquired HandySSH on my android and created a shortcut that sends the command, "ether - wake -b -i br0 [ mac ]"
So thank ASUS to provide some type of functionality, and of course Asuswrt - Merlin to make it better.
I'm sure getting an static arp would work, but I read that port scanners can trigger the wol command, so rather not do that, not a big problem. But still."
Can somebody please guide me through exactly what I need to do.
Many thanks.
Many thanks.
