Please help setting up VPN client.
router: rt-n56u running 3.4.3.9-099
I'm trying to connect to trust.zone vpn service. It seems to connect and authenticate correctly. But seems that the traffic is not being routed through the vpn.
I get the following error:
NOTE: unable to redirect default gateway -- VPN gateway parameter (--route-gateway or --ifconfig) is missing
error message stack:
Oct 1 12:12:05 RT-N56U: starting OpenVPN client...
Oct 1 12:12:05 openvpn-cli[1124]: OpenVPN 2.3.10 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Jan 31 2016
Oct 1 12:12:05 openvpn-cli[1124]: library versions: OpenSSL 1.0.1r 28 Jan 2016, LZO 2.09
Oct 1 12:12:05 openvpn-cli[1125]: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Oct 1 12:12:05 openvpn-cli[1125]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Oct 1 12:12:05 openvpn-cli[1125]: LZO compression initialized
Oct 1 12:12:05 openvpn-cli[1125]: Control Channel MTU parms [ L:1558 D:1212 EF:38 EB:0 ET:0 EL:3 ]
Oct 1 12:12:05 openvpn-cli[1125]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Oct 1 12:12:05 openvpn-cli[1125]: Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:143 ET:0 EL:3 AF:3/1 ]
Oct 1 12:12:05 openvpn-cli[1125]: nice 3 succeeded
Oct 1 12:12:05 openvpn-cli[1125]: UDPv4 link local: [undef]
Oct 1 12:12:05 openvpn-cli[1125]: UDPv4 link remote: [AF_INET]184.75.221.130:1194
Oct 1 12:12:05 openvpn-cli[1125]: TLS: Initial packet from [AF_INET]184.75.221.130:1194, sid=71e5878b 7993270d
Oct 1 12:12:05 openvpn-cli[1125]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Oct 1 12:12:05 openvpn-cli[1125]: VERIFY OK: depth=0, CN=vpn.trust.zone
Oct 1 12:12:05 openvpn-cli[1125]: Data Channel Encrypt: Cipher 'AES-128-CBC' initialized with 128 bit key
Oct 1 12:12:05 openvpn-cli[1125]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Oct 1 12:12:05 openvpn-cli[1125]: Data Channel Decrypt: Cipher 'AES-128-CBC' initialized with 128 bit key
Oct 1 12:12:05 openvpn-cli[1125]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Oct 1 12:12:05 openvpn-cli[1125]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Oct 1 12:12:05 openvpn-cli[1125]: [vpn.trust.zone] Peer Connection Initiated with [AF_INET]184.75.221.130:1194
Oct 1 12:12:07 openvpn-cli[1125]: SENT CONTROL [vpn.trust.zone]: 'PUSH_REQUEST' (status=1)
Oct 1 12:12:08 openvpn-cli[1125]: PUSH: Received control message: 'PUSH_REPLY,ping 3,ping-restart 10'
Oct 1 12:12:08 openvpn-cli[1125]: OPTIONS IMPORT: timers and/or timeouts modified
Oct 1 12:12:08 openvpn-cli[1125]: TUN/TAP device tun0 opened
Oct 1 12:12:08 openvpn-cli[1125]: TUN/TAP TX queue length set to 100
Oct 1 12:12:08 openvpn-cli[1125]: ovpnc.script tun0 1500 1558 init
Oct 1 12:12:08 openvpn-cli[1125]: NOTE: unable to redirect default gateway -- VPN gateway parameter (--route-gateway or --ifconfig) is missing
Oct 1 12:12:08 openvpn-cli[1125]: Initialization Sequence Completed
