http://i.imgur.com/OQ5GqnO.png
This is the current network. 2 and 3 are dsl routers that are nating. 1 is a router/access point that is connected to one modem. 4 is a dumb switch.
Ground floor has a repeater of access point 1.
This is the current network.All i want to to do is to create a new network that should be separated from the other.
The ubiquiti nanostation AP is the one i want to add. I want somehow to connect ubiquiti nanostation to a mikrotik router and get dhcp from there but at the same time connect to modem. The only solution i can think is double nating .Connect modem to mikrotik wan port. Is there anything else i can do ?
