I have a somewhat odd network configuration that I'm hoping the wizards here can help me get working as I need.
Here are my requirements:
Is what I'm after possible with the hardware I mentioned? Any thoughts and feedback would be most appreciated!
- I need to be able to remotely (within my house) enable & disable the wifi network. I want this to happen without exposing my router to the internet via something like Alexa or IFTTT.
- When the wifi is disabled I need the wired network to still be connected and reach the internet.
- At least two guest wireless networks (one for actual guests and one for IoT devices) that are isolated from each other, my LAN devices, and my personal wifi networks.
- Everything (possibly excluding the guest networks if it isn't feasible) leverages PiHole running on a raspberry pi.
- Modem is connected to Asus RT-AC86U
- PiHole pi is connected to AC86U and powered via its USB port
- AC86U is connected to a semi-managed switch (TP-Link TL-SG108E)
- Switch is attached to other stuff, including an Asus RT-AX86U operating as an access point
- The AC86U is powered via an outlet plug that can be controlled with a wireless remote
- Both routers are running Merlin firmware and the AX86U also has YazFi.
