In my case with AiProtection deactivated the ram is at 70% use more or less, if I activate it it goes up to 90%Acordado. Tengo ax86s con las cosas de aiprotection desactivadas. ram se arrastra hasta alrededor del 90% y todo parece estar bien.
sin embargo, si sigue subiendo al 95% o más, entonces he visto que mi enrutador falla o se reinicia.
Creo que el próximo lanzamiento de Merlin resolverá esto.
Same router running some scripts and AiProtection also a swap file and I'm at 94% and it runs fine and is stable.Hello, I have the AX-86S and I see that when I have AiProtection activated the ram memory reaches between 80 and 90% of use, I do not notice that it causes problems but I did think about whether that is good or it could be problematic, in fact I thought to replace it with the PRO version that has double the ram.
| Thread starter | Title | Forum | Replies | Date |
| S | High RAM usage seemingly causing WiFi to not function | Asuswrt-Merlin | 22 | |
High CPU load when enabling Traffic Analyzer - Statistic on GT-AXE16000 | Asuswrt-Merlin | 4 | |
| U | aaews process high cpu load | Asuswrt-Merlin | 1 |
We use essential cookies to make this site work, and optional cookies to enhance your experience.
