so its backend is LTE? that's wierd but cool
TDD-LTE is not today's LTE (in the US anyway).
TDD-LTE was/is a time division duplexing (TDD) form of LTE. GSM uses/used TDD.
Sprint is ever the goof-ball. Smartphone makers for US customers won't want to spend much R&D on TD-LTE.2.5GHz that Sprint is deploying is TDD-LTE, as that is unpaired spectrum... they're FDD in the 800/850/1900 bands...
Maybe Sprint is again trying to recycle their ill-gotten MMDS spectrum in 2.5GHz.
I avoid such proprietary products. Beyond dependance upon their servers, if that small startup fails, and you are dependent on their proprietary networking, then when you need a replacement or addition, you are SOL.
That's why we need the IEEE to promulgate a mesh standard. Years go by and there is none in consumer-space - due to lack of need.
The serious meshes are from Tropos and Cisco, with backhaul on a proprietary mesh and user access on a different radio (usually) with vanilla 802.11/WiFi.
But the products being discussed don't claim compliance with IEEE. They seem to prefer proprietary methods.Mesh is standardized by IEEE 802.11s
Here's a good whitepaper on it.
http://www.cwnp.com/uploads/802-11s_mesh_networking_v1-0.pdf
sfx
And if they're proprietary, they're just another Cisco, et al 'mesh'.But the products being discussed don't claim compliance with IEEE. They seem to prefer proprietary methods.
Proprietary definitely isn't the way to go, but sometimes it's worth the cost and risk. The Meraki solution I use is completely proprietary. So much so that the LAN ports on the APs can't even be used for regular ethernet traffic, but the system is super rock-solid and I wouldn't trade it unless I had to.Yes. That's why one should avoid proprietary anything with small companies. And avoid if at all possible from Cisco/Juniper/Aruba and other larger ones.
It's a matter of risk.
Cisco acquired Meraki 3 years ago, right?
Not always good though... Cisco has acquired many and they were stirred into and lost in the corporate soup. Like Clearwire.
Welcome To SNBForums
