Home Network Build
samb
Hello,
I have just finished wiring up my home network and would like any comments or problems you may foresee with the current wired setup?
Sam
Not sure what kind of feedback your looking for as there is no context as to what devices are located where and what your scenario is. The only thing I might changed based solely on this network map is I would move the NAS off the router and onto a switch if possible. It will most likely be faster that way and it keeps unnecessary traffic off your router.
