Housing of the RT-AX88u and RT-AX88u Pro
gogreen1
I want to wall-mount my RT-AX88u Pro. Is the housing of the RT-AX88u and RT-AX88u Pro the same? I ask because I saw a wall mount that fits the RT-AX88u. The Etsy manufacturer isn't sure if it would fit around the RT-AX88u Pro. It will fit if the outside housing is the same. Comparing the pictures of the two, the housing does appear to be the same.
