You don't run any power saving modes on a router. Its just that simple.No I don't work for Asus and I'm not defending anything. But if you continue to post factually incorrect or irrelevant statements you should expect to be corrected.
Again, he's not running power saving. It's just that simple.You don't run any power saving modes on a router. Its just that simple.
That's only because he's turned off all logging on the router. He needs to turn that back on.Most of the log messages are node MAC address related.
Neither do we because your log file contains no useful information since the change you made to the router's logging on October 21st. But it has nothing to do with sleep states or kernel configuration.
I suggest you change "Log only messages more urgent than" on the System Log - General Log page to "all" and then we might be able to see some actual error messages when the problem next occurs.
your reply contradicts what the log revealed. The Asus firmware has bad OS configuration, which is having power savings turned on, and the user had nothing to do with setting these improper settings.Again, he's not running power saving. It's just that simple.
There is nothing in the log that suggests any problem related to power saving.your reply contradicts what the log revealed.
What are the exact symptoms? You initially said that you lose connection to the internet, now you're saying "it freezes". Which is it?again it freeze...
ping 8.8.8.8.tailscale. I suggest you disable that and any other custom scripts (Administration - System > Enable JFFS custom scripts and configs = No) while trying to diagnose this problem.See my updated post above.My router lost the internet connection, all devices lost their internet access, I need to switch off the router and restart it again.
Check in 90 minutes if it renews automatically.View attachment 63273
It has it: now have i do anything?
Just wait and see what happens. In theory the router should start asking for a new lease when it reaches 2 hours remaining. If it doesn't doesn't get one and the lease expires that could be the problem.View attachment 63273
If it’s a dhcp lease problem, try to unplug the WAN cable next time, count to 10, then plug it in again. See if it recovers instead of power cycling the router.I need to switch off the router and restart it again.
Jan 6 13:29:15 dnsmasq-dhcp[5446]: DHCPOFFER(br0) 192.168.0.199 48:e1:e9:78:9b:b6
Jan 6 13:29:21 rc_service: cfg_server 2703:notify_rc restart_time;restart_leds;restart_usb_idle;restart_firewall;
Jan 6 13:29:21 ntpd: Stopped ntpd
Jan 6 13:29:21 dropbear[2808]: Early exit: Terminated by signal
Jan 6 13:29:21 syslogd exiting
Jan 6 13:29:21 syslogd started: BusyBox v1.25.1
Jan 6 13:29:21 kernel: klogd started: BusyBox v1.25.1 (2024-11-17 14:17:59 EST)
Jan 6 13:29:21 dropbear[8138]: Running in background
Jan 6 13:29:37 hour_monitor: daemon is starting
Jan 6 13:30:15 dnsmasq-dhcp[5446]: DHCPDISCOVER(br0) 48:e1:e9:78:9b:b6
We use essential cookies to make this site work, and optional cookies to enhance your experience.
