how activate encrypted SNI asus rt ax88u
@dave14305
Many thanks for your analysis and response which helps me a lot.
It is therefore preferable to activate "DNSSEC support" with "Validate unsigned DNSSEC replies" even if the cloudflare test displays this error ?
Yes, keep both enabled. Disable DNSSEC temporarily if you want to prove DoT works, but enable it for normal use.
Thank you very much for that specific answer.
It is really nice to have helped me on this subject.
Good night.
