How can I get old version of transmission for Entware?
There is something wrong with 010_libtransmission_fallocate64_eglibc.patch, I found the way to deal with from this post. https://github.com/openwrt/packages/issues/1088
I successfully built Transmission 2.52 for Entware-ARM, by applying these two patch files. Note that "010_libtransmission_fallocate64_eglibc.patch" has different contents than the patch file included in the most recent openwrt feed. Just open the patch file to verify these contents.
~/openwrt_trunk/feeds/packages/net/transmission/patches/010_libtransmission_fallocate64_eglibc.patch
(This one is different)
--- a/libtransmission/fdlimit.c 2014-07-01 20:08:59.000000000 +0300
+++ b/libtransmission/fdlimit.c 2014-07-13 13:30:17.000000000 +0300
@@ -22,7 +22,8 @@
  #include <fcntl.h>
#endif
-#ifdef HAVE_FALLOCATE64
+/* no need to define fallocate64 in glibc/eglibc case */
+#if defined (__UCLIBC__) && (HAVE_FALLOCATE64)
  /* FIXME can't find the right #include voodoo to pick up the declaration.. */
  extern int fallocate64 (int fd, int mode, uint64_t offset, uint64_t len);
#endif
~/openwrt_trunk/feeds/packages/net/transmission/patches/030-fix-musl-build.patch
(This one is good)
Index: transmission-2.84/libtransmission/bitfield.c
--- transmission-2.84.orig/libtransmission/bitfield.c
+++ transmission-2.84/libtransmission/bitfield.c
@@ -7,6 +7,8 @@
  * $Id: bitfield.c 14302 2014-06-29 01:42:38Z jordan $
+#define __NEED_ssize_t
#include <assert.h>
#include <stdlib.h> /* realloc () */
#include <string.h> /* memset */
@@ -15,6 +17,7 @@
#include "bitfield.h"
#include "utils.h" /* tr_new0 () */
const tr_bitfield TR_BITFIELD_INIT = { NULL, 0, 0, 0, false, false };
Index: transmission-2.84/libtransmission/fdlimit.h
--- transmission-2.84.orig/libtransmission/fdlimit.h
+++ transmission-2.84/libtransmission/fdlimit.h
@@ -11,6 +11,8 @@
  #error only libtransmission should #include this header.
#endif
+#define __NEED_off_t
#include "transmission.h"
#include "net.h"
So I have the Entware-ARM packages for Transmission 2.52. Let me know if you want it uploaded. Where?
Doesn't mean having to respond to a 10 years old post...
Locked.
