el97
Hi everyone at the SNBforum! To begin with I'm really new with changing stuff in my router and I would consider my self as a beginner in coding overall. I have recently flashed my router with the latest Merlin firmware and also installed some add-ons. It's going pretty well but I feel like all the data is a bit all over the place and I want it to be more accessible and with a better overview.
So after some searching I found this great Grafana dashboard that uses scripts to import all the information from the router. So I started to set up the server that imports the data and shows it in Grafana but I run in to some problems straight away. It began with the authentication with took some days to solve but now I'm stuck with another problem. One of the scripts is using the update.cgi as an URL to access some of the info but it looks like it doesn't work. When i paste it in my browser I get redirected to the login screen straight away and nothing more. So because of that the server can't import the data.
Does anyone here knows how to get it working as it should?
My router is an RT-AC88U
I have flashed Merlin Version 386.4
The link for the project is https://github.com/jphilll/GrafanaAsusRouterMonitor
