How to remove the 2.4 ghz 5 ghz and cpu coversMy 87U runs at 50˚, 70˚ and 88˚ right now. Ambient temperature is 27˚.
I've had mine completely apart the other day to look for damage lightning did to the WAN port.How to remove the 2.4 ghz 5 ghz and cpu covers
How to remove the cpu heatpadI've had mine completely apart the other day to look for damage lightning did to the WAN port.
But I can't say how to remove them as I did not look too closely at them.
I've had it this far apart:How to remove the cpu heatpad
i want to know how to take it apartI've had it this far apart:
https://wiki.openwrt.org/toh/asus/rt-ac87u
As it says in the article. Remove the four screws, two are under the rubber triangles (I just poked through with the screwdriver).i want to know how to take it apart
Then gently pry it apart at the seam on the side with a flat object. Swiss Army knive works best...
Please tell me if a new asuswrt build is available for my rt-ac87u![]()
You folks have been busy today I see.
As I said before, these temperatures are perfectly normal, there is nothing to worry about it.On cpu between 60 and 90
Please tell me if a new asuswrt build is available for my rt-ac87uAs I said before, these temperatures are perfectly normal, there is nothing to worry about it.
380.68_0 is the latest.Please tell me if a new asuswrt build is available for my rt-ac87u
Where a new build will be available for my rt-ac87u380.68_0 is the latest.
OkLet me check my crystal ball
You have checked your crystal ball now
you have checked your crystal ball nowLet me check my crystal ball
Welcome To SNBForums
