hotsauce2007
I used to turn on the web from the wan to use ddns and setup in pingdom to check the internet availability ![Oops! :oops: :oops:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f633.png)
VPN server - Open VPN page has three links like:I still prefer to rely on a VPN myself - it's not that hard to setup, even on a smart phone.
, but none of them works. Do they lead to instructions how to setup VPN? How to set VPN on Android?
Thanks!
Those are general instructions. If you openvpn tab selected there is an underlined link you can clock in to download the .ovpn config file to use on the remote client.VPN server - Open VPN page has three links like:
Thanks!
And what is the best client to use on Android?Those are general instructions. If you openvpn tab selected there is an underlined link you can clock in to download the .ovpn config file to use on the remote client.
there isn't much option for you.And what is the best client to use on Android?
Is it possible to use the GUI? Format JFFS partition after reboot, then reboot, reflash the firmware, then restore factory default? I'm going to assume not to restore settings and just setup from scratch?The best way after known security breach is format jffs and reflash with factory setting reset.
Best way!!Is it possible to use the GUI? Format JFFS partition after reboot, then reboot, reflash the firmware, then restore factory default? I'm going to assume not to restore settings and just setup from scratch?
HHHHHUURRRRRRRRRAAAAAAAAAHHHHHHHHHHH!!!Just look on these forums,there are dozens of posts about OpenVPN.
I mean, I made it working. That means, VPN on Android cellphone is working now and I am able to login to router.
Now there are more questions for you, Merlin:
1) I can set up to 32 user names and passwords on "VPN Server" page - what are they for? I just created a profile on a client by importing .ovpn file and I am able to VPN to the router without entering any credentials. Username is just "client" on "VPN Status" page.
2) Is there a way to log in router with restricted rights? Another login? The user must be able only to turn on/off "Parental Controls" to let kids go to Internet / stop it.
3) Is there a way to start ParentalControl.asp page with a parameters in query part to on/off "Parental Controls"?
And thank you so much for your work!
Vadim
I want to know the same, no google results at all, maybe we can run a test using some tools of it?
Welcome To SNBForums
