BreakingDad
Is there a way to add more channels, other than 36,40 and 40 to the 5ghz band?
I'm based in the UK and the region config forces these channels that all fall within the wii u pad range.
I've got around it by turning off the 5ghz for now, but I want to use the 5ghz on a couple of my machines.
The reason I want to change them is because the wii U gamepad uses this range (5150-5250 Mhz) so therefore if I use the 5ghz band on the pc, it interferes with the wii U gamepad.
Would be good if I could use a channel from say, korea, singapore or Japans range so I don't get this interference.
I'm not really bothered if its technically illegal, as long as I wont interfere with someones pacemaker or something.... If I interrupt their soap watching so be it
All advice would be appreciated.
Cheers
Cheers
