How to blacklist/block sites using MVPS Hosts file with DNSCrypt-Proxy v2
Thanks for your help. You were right I could click the boxes with another browser.
I did factory reset Voxel:s fantastic firmware. I then installed your great addon.
Sadly the DNS-crypt v 2 still kills my internet. Cant visit sites.
Stubby seeems to work without problems, but I cant see that any adds disappears.
UPDATE! In my logfile for DNSCrypt
[2019-12-30 13:31:03] [NOTICE] dnscrypt-proxy 2.0.36
[2019-12-30 13:31:03] [NOTICE] Network connectivity detected
[2019-12-30 13:31:03] [NOTICE] Source [public-resolvers] loaded
[2019-12-30 13:31:03] [NOTICE] Source [relays] loaded
[2019-12-30 13:31:03] [NOTICE] Firefox workaround initialized
[2019-12-30 13:31:03] [NOTICE] Loading the set of blocking rules from [blacklist.txt]
[2019-12-30 13:31:03] [FATAL] open blacklist.txt: no such file or directory"
Can it be that you don't use the add-on for this,
since you have the wrong path to the blacklist?
It should be: [NOTICE] Loading the set of blocking rules from [/etc/blacklist.txt]
Also if using the add-on, which blacklists have you checked and how many addresses are filtered according to the add-on?
Example when checking AdAway and Submit, and then doing a refresh of the page:
Warning: Checking all providers will block very many addresses. Now filtering: 12488
AdAway (12488) - https://adaway.org
With Adway checked I like you filter 12488 adresses. After i checked in adway I once again tried dnscrypt v2 and it killed my internet.
About not using the addon I dont know. I have installed it and I see all of your services.
"System Version Information (....) FW:V1.0.4.37HF (Voxel). Kamoj Add-on:5.00."
