How to block FTP access from WAN on RT-N66U
mberteotti
I've a RT-N66U with 3.0.0.4.374.35_4 FW. I'd like to use FTP only on intranet and should be not accessible from WAN. How can I do that? By default FTP is accessible from WAN (port 21 is open on WAN).
For example on rt-n56u ther is a switch that turns access to FTP server from WAN on/off... Not found in RT-N66U.
Thank you.
Marco B.
under usb application > media server > ftp share disable FPT
and enable only the one under network places (samba)
Yes, but this disables FTP completely and FTP doesn't work in intranet too (no LAN and no WAN ftp server at all).
Thanks.
Marco
hmm that does it for me , i have those settings and the sharing works only on LAN
do you have share with an account enabled on samba part?
what build do you have? i have 3.0.0.4.374.38_2-em
I've share SAMBA share enabled with no account (anonymous). Samba share works perfectly, no access from WAN only from LAN. I've 3.0.0.4.374.35_4 build, waiting for a FW release that has -EM switch integrated and default not exeperimental.
Thank you!!
Marco B.
so where is the problem? i though that is what you want, right?
No.
I need FTP and SAMBA too, SAMBA works ok but FTP, if enabled, is opened to WAN and I don't want it. Sorry for my English, probably I can't explain myself correctly.
Marco
oh, ok i understand what you say ......
i dont know if is possible and if it is i dont know if can be done from the web interface....might need some scripting with which i cannot help you :(
maybe someone can make you a script or give you some firewall rules that will cut off the port21 connection to wan
for my curiosity why do you need a lan FTP when samba performs exactly the same function ?
I've a couple of IP cameras that can write only to an FTP server (when triggered by a motion detection) not to a SAMBA server unfortunately.;)
Bye.
Try this rule to block port 21 from wan:
iptables -I INPUT --dport 21 -j DROP
without specifying the wan interface, i think that would drop port 21 traffic from the lan, too.
so, something like;
iptables -I INPUT -i eth0 -p tcp --dport 21 -j DROP
i have been using /jffs/scripts/firewall-start for these rules. well, for filtering outgoing ports.
for that, i use:
iptables -I FORWARD -p tcp --dport 21 -j DROP
to drop outgoing requests to an ftp server on the internet, for example.
make sure the script starts with
#!/bin/sh
and use chmod a+rx /jffs/scripts/* when you're done
As there are different ways to accomplish things, these are the couple ones that have worked for me.
iptables -I INPUT -p tcp --destination-port 21 -j DROP
iptables -I INPUT -p tcp --destination-port 21 --source `nvram get lan_ipaddr`/`nvram get lan_netmask` -j ACCEPT
Great! These work for me too. Now I can access FTP from LAN and not from WAN!
Sinshiva is right:using "iptables -I INPUT --dport 21 -j DROP" all FTP call are dropped not only WAN ones. But his command "iptables -I INPUT -i eth0 -p tcp --dport 21 -j DROP" doesn't work. etho is the WAN interface?
Thank you EronRackzak AMD Sinshiva :)
if inserting didn't work, try appending, sorry;
iptables -A INPUT -i eth0 -p tcp --dport 21 -j DROP
ah, maybe not. it might work differently with PPPoE, if that's what you're using. post the output of;
ifconfig -a
