how to block ip addresses after "x" number of failed attempts, or by geo-location
I am unfortunately in the class of folks hoping to see entware on my RT-AC68R. With that said optware is available and I use nano instead of VI for text editing:
ipkg update
ipkg install nano
Hope it helps
I'm talking about script syntax, not about editors.
This feature is already there in the GUI.
In Administration Menu, System Tab, "Enable SSH Brute Force Protection" option.
The option in the GUI appears only to work for SSH to the router itself. I've forwarded SSH to a server on my network and unfortunately the GUI doesn't work for this.
ipset blocking doesnt work on RT-AC66U ?
Hello,
I tried to block Tor nodes and countries with the script in:
https://github.com/RMerl/asuswrt-merlin/wiki/Using-ipset
but it doesnt seem to work on my RT-AC66U with Merlin build 376.44 (3-Aug-2014). This is the first time I tested ipset. I tested open ports with ShieldsUp from grc.com
ipset v4.5, protocol version 4.
Kernel module protocol version 4.
iptables v1.3.8
First I tested with blocking all of US, using CIDR from https://www.countryipblocks.net/country_selection.php
That failed.
Then I changed the script so that all probe nodes of grc.com were added as if it were Tor nodes, and I added 4.0.0.0/8 as nethash for "country blocking" (was already present in the US CIDR):
admin@RT-AC66U:/tmp/home/root# ipset -L
Type: iphash
References: 1
Header: hashsize: 1024 probes: 8 resize: 50
Members:
4.79.142.207
4.79.142.204
4.79.142.199
4.79.142.203
4.79.142.202
4.79.142.200
4.79.142.201
4.79.142.205
4.79.142.206
4.79.142.193
4.79.142.195
4.79.142.192
4.79.142.194
4.79.142.196
4.79.142.198
4.79.142.197
Type: nethash
References: 1
Header: hashsize: 1024 probes: 4 resize: 50
Members:
4.0.0.0/8
admin@RT-AC66U:/tmp/home/root# iptables -L (output cropped)
Chain INPUT (policy ACCEPT)
target prot opt source destination
DROP all -- anywhere anywhere set BlockedCountries src
DROP all -- anywhere anywhere set TorNodes src
Looking at the above output as the iptables novice that I am, it seems that it should work, but it doesn't. ShieldsUp (grc.com) keeps saying that I failed.
The port I am testing is being forwarded by the virtual server webui to my NAS. When I deploy firewall GeoIP blocking on my NAS, ShieldsUp says that I passed (full stealth). However, I want to block on the router instead of the NAS.
I have read a remark somewhere else on this forum, stating that it might be related to the RT-AC66U using an old version of iptables (1.3.8).
Is that the cause?
Can anyone confirm that blocking with ipset is, or is not, working with an RT-AC66U ?
