I have it working with some scripts on my router. Not sure if it would work on other router types:
https://www.snbforums.com/threads/rt-ax86u-pro-lan-port-on-guest-network.91966/post-928266
Rung
You are correct. Yes, everything on the switch would be isolated, but could still be useful for some but maybe not op.But doesn't that assume the secondary switch will be dedicated to that LAN port on the primary router? IOW, *any* device on the secondary switch ends up isolated from the private network. Not sure if that's what the OP is looking for. Not unless the OP is willing/able to plug the device into that LAN port on primary router directly.
Also, wouldn't a couple of managed switches work for that? I understand they are not expensive. Combine and uncombine two ports on the router: the isolated port and a regular port.But doesn't that assume the secondary switch will be dedicated to that LAN port on the primary router? IOW, *any* device on the secondary switch ends up isolated from the private network. Not sure if that's what the OP is looking for. Not unless the OP is willing/able to plug the device into that LAN port on primary router directly.
Welcome To SNBForums
