I am having trouble configuring VPN Director so that anyone on the LAN can connect to the router admin page https://www.asusrouter.com:8443/ and other internal IPs, while connections to the Internet would use a WG client. What keeps happening is that I eventually lose access to the router admin page and need to factory reset the router.
I know I have limited networking knowledge and there is an obvious mistake here. I thought "Local IP" meant the IP assigned to the device and "Remote IP" meant the IP the device is trying to connect to. If this is incorrect, what are the definitions of these terms?
On the third row, I have 192.168.0.0/16 because clients on the guest network have a different IP range, like 192.168.101.*, and I also want them to go through the VPN. It is also a backup VPN client in case WGC1 is down for clients with the IP range 192.168.50.*
Enable | Description | Local IP | Remote IP | Iface |
Y | LAN to Class C bypass VPN | 192.168.50.0/24 | 192.168.0.0/16 | WAN |
Y | LAN clients to WGC1 | 192.168.50.0/24 | WGC1 | |
Y | All clients to WGC2 | 192.168.0.0/16 | WGC2 |
