How to disable Windows 10 tracking using ipset + Entware
Is anyone having ipset problems using Win10tracking with 380.57? The problem I'm having is...
admin@RT-AC68U-F000:/jffs/scripts# sh firewall-start
Done.
iptables v1.4.14: Set Win10tracking doesn't exist.
Try `iptables -h' or 'iptables --help' for more information.
admin@RT-AC68U-F000:/jffs/scripts# ipset --list Win10tracking
ipset v4.5: Unknown set
Done.
I am able to do a cat on /jffs/Win10tracking.txt, /jffs/scripts/firewall-start and /jffs/configs/dnsmasq.conf.add. ipset -L returns nothing. Checking ipset -V lists correct version. Just that the shebang seems to contain an error. It says cannot find Win10tracking or Win10tracking.txt ... Hope this helps to figure out the problem? 378.56_2 and the 380.57 alphas had no ipset errors. The 380.57 release gives the ipset errors...
I figured out the error. The script does not work if it is wordwrapped. Unwrapped it in nano and it's working again. Make sure the script is in one line before the semicolon. I guess as I do not have a shebang tester. Alls good and well. It became sensitive after 380.57.
Is script in first post still working for blocking win 10 tracking?
sent from Kodi 17 Krypton
i installed this win 1o tracking script. i put this into terminal and got this...is this ok:
login as: xxxxx
xxxxx@xxx.xxx.x.x's password:
ASUSWRT-Merlin RT-AC68U_3.0.0.4 Thu Dec 24 18:54:10 UTC 2015
admin@RT-AC68U:/tmp/home/root# ipset --list Win10tracking
Type: iphash
References: 1
Header: hashsize: 1024 probes: 8 resize: 50
Members:
and at syslog i got all that dnsmasq addresses...is that normal or i can to disable this? where to see if the script blocking something?
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain www.msftncsi.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain s0.2mdn.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain s.gateway.messenger.live.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain reports.wes.df.telemetry.microsoft.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain redir.metaservices.microsoft.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain rad.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain rad.live.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain pricelist.skype.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain preview.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain pre.footprintpredict.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain oca.telemetry.microsoft.com.nsatc.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain msntest.serving-sys.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain msnbot-65-55-108-23.search.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain msftncsi.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain m.hotmail.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain m.adnxs.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain live.rads.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain lb1.www.ms.akadns.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain i1.services.social.microsoft.com.nsatc.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain h1.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain g.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain flex.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain feedback.windows.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain feedback.search.microsoft.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain feedback.microsoft-hohm.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain fe2.update.microsoft.com.akadns.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain ec.atdmt.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain diagnostics.support.microsoft.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain df.telemetry.microsoft.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain db3aqu.atdmt.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain cs1.wpc.v0cdn.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain corpext.msitadfs.glbdns2.microsoft.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain corp.sts.microsoft.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain compatexchange.cloudapp.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain choice.microsoft.com.nsatc.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain cds26.ams9.msecn.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain cdn.atdmt.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain c.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain c.atdmt.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain bs.serving-sys.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain b.rad.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain b.ads2.msads.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain b.ads1.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain az512334.vo.msecnd.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain az361816.vo.msecnd.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain apps.skype.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain aka-cdn-ns.adtech.de
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain aidps.atdmt.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain ads1.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain ads1.msads.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain ads.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain adnxs.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain adnexus.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain ad.doubleclick.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain ac3.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-0009.a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-0008.a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-0007.a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-0006.a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-0005.a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-0004.a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-0003.a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-0002.a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a-0001.a-msedge.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a.rad.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a.ads2.msn.com
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a.ads2.msads.net
Feb 19 09:30:10 dnsmasq[1374]: using nameserver 127.0.0.1#1919 for domain a.ads1.msn.com
looks right to me. you can also use the command ipset -L eventually you should see a list of IP addresses that were blocked.
is possible to stop writing in syslog this kind dnsmasq?
somebody else would have to answer this. I don't know.
Can you by any chance upload the unwrapped script? I'll be happy to test it.
hello, still do not know if possible to stop write this kinds logs in syslog with windows 10 tracking script? any solution for this?
As part of the upcoming AB-Solution 1.1 release as an add-on, these entries will log to the dnsmasq logfile, if logging is enabled.
yes i understand....but with this currently script these entries write in logfile every hour.....so there are hundreds of these logs.....this is annoying....
Just wondering if this is still working for anyone?
I get zero members in the list after manually trying to connect to some to the sites (which succeed)
admin@RT-AC68U-8858:/tmp/home/root# ipset --list
Type: iphash
References: 1
Members:
I have tried the old version and the more recent one documented in the wiki..
GF
I have Merlin fork 374.43_2-16E1 and the same problem:
admin@RT-N16-48C5:/tmp/home/root# ipset --list Win10tracking
Can you please give unwrapped script?
I'm using John's fork also. The easy way is just to use AB-Solution and insert the following in /tmp/mnt/sda1/adblocking.
#Microsoft
0.0.0.0 a-0001.a-msedge.net
0.0.0.0 a-0002.a-msedge.net
0.0.0.0 a-0003.a-msedge.net
0.0.0.0 a-0004.a-msedge.net
0.0.0.0 a-0005.a-msedge.net
0.0.0.0 a-0006.a-msedge.net
0.0.0.0 a-0007.a-msedge.net
0.0.0.0 a-0008.a-msedge.net
0.0.0.0 a-0009.a-msedge.net
0.0.0.0 a-msedge.net
0.0.0.0 a.ads1.msn.com
0.0.0.0 a.ads2.msads.net
0.0.0.0 a.ads2.msn.com
0.0.0.0 a.rad.msn.com
0.0.0.0 a0001.a-msedge.net
0.0.0.0 a0002.a-msedge.net
0.0.0.0 a0003.a-msedge.net
0.0.0.0 a0004.a-msedge.net
0.0.0.0 a0005.a-msedge.net
0.0.0.0 a0006.a-msedge.net
0.0.0.0 a0007.a-msedge.net
0.0.0.0 a0008.a-msedge.net
0.0.0.0 a0009.a-msedge.net
0.0.0.0 a1621.g.akamai.net
0.0.0.0 a1856.g2.akamai.net
0.0.0.0 a1961.g.akamai.net
0.0.0.0 a23-218-212-69.deploy.static.akamaitechnologies.com
0.0.0.0 a248.e.akamai.net
0.0.0.0 a978.i6g1.akamai.net
0.0.0.0 ac3.msn.com
0.0.0.0 ad.doubleclick.net
0.0.0.0 adnexus.net
0.0.0.0 adnxs.com
0.0.0.0 ads.msn.com
0.0.0.0 ads1.msads.net
0.0.0.0 ads1.msn.com
0.0.0.0 aidps.atdmt.com
0.0.0.0 aka-cdn-ns.adtech.de
0.0.0.0 aka.ms
0.0.0.0 americas2.notify.windows.com.akadns.net
0.0.0.0 any.edge.bing.com
0.0.0.0 apps.skype.com
0.0.0.0 atlas.c10r.facebook.com
0.0.0.0 az361816.vo.msecnd.net
0.0.0.0 az512334.vo.msecnd.net
0.0.0.0 b.ads1.msn.com
0.0.0.0 b.ads2.msads.net
0.0.0.0 b.rad.msn.com
0.0.0.0 bing.com
0.0.0.0 bingads.microsoft.com
0.0.0.0 bl3302.storage.live.com
0.0.0.0 bl3302geo.storage.dkyprod.akadns.net
0.0.0.0 bn1wns2011508.wns.windows.com
0.0.0.0 bs.serving-sys.com
0.0.0.0 c-0001.c-msedge.net
0.0.0.0 c.atdmt.com
0.0.0.0 c.msn.com
0.0.0.0 c.msn.com.nsatc.net
0.0.0.0 cdn.atdmt.com
0.0.0.0 cdnjs.cloudflare.com.cdn.cloudflare.net
0.0.0.0 cdp1.public-trust.com
0.0.0.0 cds26.ams9.msecn.net
0.0.0.0 choice.microsoft.com
0.0.0.0 choice.microsoft.com.nsatc.net
0.0.0.0 client.wns.windows.com
0.0.0.0 compatexchange.cloudapp.net
0.0.0.0 corp.sts.microsoft.com
0.0.0.0 corpext.msitadfs.glbdns2.microsoft.com
0.0.0.0 cs1.wpc.v0cdn.net
0.0.0.0 cy2.displaycatalog.md.mp.microsoft.com.akadns.net
0.0.0.0 db3aqu.atdmt.com
0.0.0.0 dc.services.visualstudio.com
0.0.0.0 df.telemetry.microsoft.com
0.0.0.0 diagnostics.support.microsoft.com
0.0.0.0 directory.services.live.com
0.0.0.0 directory.services.live.com.akadns.net
0.0.0.0 dns.msftncsi.com
0.0.0.0 download-ssl.msgamestudios.com
0.0.0.0 dt.adsafeprotected.com
0.0.0.0 e-0009.e-msedge.net
0.0.0.0 e2835.dspb.akamaiedge.net
0.0.0.0 e7341.g.akamaiedge.net
0.0.0.0 e7502.ce.akamaiedge.net
0.0.0.0 e8218.ce.akamaiedge.net
0.0.0.0 ec.atdmt.com
0.0.0.0 en-us.appex-rf.msn.com
0.0.0.0 eu.vortex.data.microsoft.com
0.0.0.0 fe2.update.microsoft.com.akadns.net
0.0.0.0 fe2.ws.microsoft.com.nsatc.net
0.0.0.0 fe3.delivery.dsp.mp.microsoft.com.nsatc.net
0.0.0.0 fe3.delivery.mp.microsoft.com
0.0.0.0 feedback.microsoft-hohm.com
0.0.0.0 feedback.search.microsoft.com
0.0.0.0 feedback.windows.com
0.0.0.0 flex.msn.com
0.0.0.0 fw.adsafeprotected.com
0.0.0.0 g.msn.com
0.0.0.0 go.microsoft.com
0.0.0.0 googleads4.g.doubleclick.net
0.0.0.0 h1.msn.com
0.0.0.0 hostedocsp.globalsign.com
0.0.0.0 i1.services.social.microsoft.com
0.0.0.0 i1.services.social.microsoft.com.nsatc.net
0.0.0.0 ieonlinews.microsoft.com
0.0.0.0 inference.location.livenet.akadns.net
0.0.0.0 ipv6.msftncsi.com
0.0.0.0 ipv6.msftncsi.com.edgesuite.net
0.0.0.0 lb1.www.ms.akadns.net
0.0.0.0 li581-132.members.linode.com
0.0.0.0 licensing.md.mp.microsoft.com
0.0.0.0 live.rads.msn.com
0.0.0.0 login.live.com
0.0.0.0 login.live.com.nsatc.net
0.0.0.0 m.adnxs.com
0.0.0.0 m.hotmail.com
0.0.0.0 m221.absolute.com
0.0.0.0 mobileads.msn.com
0.0.0.0 mpd.mxptint.net
0.0.0.0 mscrl.microsoft.com
0.0.0.0 msedge.net
0.0.0.0 msftncsi.com
0.0.0.0 msnbot-65-55-108-23.search.msn.com
0.0.0.0 msntest.serving-sys.com
0.0.0.0 ns1.msft.net
0.0.0.0 ns2.msft.net
0.0.0.0 ns3.msft.net
0.0.0.0 ns4.msft.net
0.0.0.0 ns5.msft.net
0.0.0.0 ns6.msft.net
0.0.0.0 oca.telemetry.microsoft.com
0.0.0.0 oca.telemetry.microsoft.com.nsatc.net
0.0.0.0 OneSettings-bn2.metron.live.com.nsatc.net
0.0.0.0 onesettings-cy2.metron.live.com.nsatc.net
0.0.0.0 origin.windows.microsoft.com.akadns.net
0.0.0.0 osiprod-scus-snow-000.cloudapp.net
0.0.0.0 pre.footprintpredict.com
0.0.0.0 preview.msn.com
0.0.0.0 pricelist.skype.com
0.0.0.0 prod-w.nexus.live.com.akadns.net
0.0.0.0 rad.live.com
0.0.0.0 rad.msn.com
0.0.0.0 redir.metaservices.microsoft.com
0.0.0.0 register.mesh.com
0.0.0.0 reports.wes.df.telemetry.microsoft.com
0.0.0.0 s.gateway.messenger.live.com
0.0.0.0 sc.iasds01.com
0.0.0.0 schemas.microsoft.akadns.net
0.0.0.0 secure.adnxs.com
0.0.0.0 secure.flashtalking.com
0.0.0.0 services.wes.df.telemetry.microsoft.com
0.0.0.0 settings-sandbox.data.microsoft.com
0.0.0.0 settings-win.data.microsoft.com
0.0.0.0 settings.data.glbdns2.microsoft.com
0.0.0.0 skyapi.live.net
0.0.0.0 skyapi.skyprod.akadns.net
0.0.0.0 skydrive.wns.windows.com
0.0.0.0 sls.update.microsoft.com.akadns.net
0.0.0.0 sm.mcafee.com
0.0.0.0 so.2mdn.net
0.0.0.0 solitaireprod.maelstrom.xboxlive.com
0.0.0.0 spynetus.microsoft.akadns.net
0.0.0.0 sqm.df.telemetry.microsoft.com
0.0.0.0 sqm.telemetry.microsoft.com
0.0.0.0 sqm.telemetry.microsoft.com.nsatc.net
0.0.0.0 ssw.live.com
0.0.0.0 ssw.live.com.nsatc.net
0.0.0.0 static.2mdn.net
0.0.0.0 statsfe1.ws.microsoft.com
0.0.0.0 statsfe2.update.microsoft.com.akadns.net
0.0.0.0 statsfe2.ws.microsoft.com
0.0.0.0 storeedgefd.dsx.mp.microsoft.com
0.0.0.0 su3.mcafee.com
0.0.0.0 survey.watson.microsoft.com
0.0.0.0 telecommand.telemetry.microsoft.com
0.0.0.0 telecommand.telemetry.microsoft.com.nsatc.net
0.0.0.0 telemetry.appex.bing.net
0.0.0.0 telemetry.appex.bing.net:443
0.0.0.0 telemetry.microsoft.com
0.0.0.0 telemetry.urs.microsoft.com
0.0.0.0 travel.tile.appex.bing.com
0.0.0.0 tunnel.cfw.trustedsource.org
0.0.0.0 ui.skype.com
0.0.0.0 updatekeepalive.mcafee.com
0.0.0.0 urs.microsoft.com.nsatc.net
0.0.0.0 v10.vortex-win.data.metron.life.com.nsatc.net
0.0.0.0 v10.vortex-win.data.microsoft.com
0.0.0.0 view.atdmt.com
0.0.0.0 vortex-bn2.metron.live.com.nsatc.net
0.0.0.0 vortex-cy2.metron.live.com.nsatc.net
0.0.0.0 vortex-hk2.metron.live.com.nsatc.net
0.0.0.0 vortex-sandbox.data.microsoft.com
0.0.0.0 vortex-win.data.microsoft.com
0.0.0.0 vortex.data.microsoft.com
0.0.0.0 watson.live.com
0.0.0.0 watson.microsoft.com
0.0.0.0 watson.ppe.telemetry.microsoft.com
0.0.0.0 watson.telemetry.microsoft.com
0.0.0.0 watson.telemetry.microsoft.com.nsatc.net
0.0.0.0 wes.df.telemetry.microsoft.com
0.0.0.0 wildcard.appex-rf.msn.com.edgesuite.net
0.0.0.0 wildcard.twimg.com
0.0.0.0 win10.ipv6.microsoft.com
0.0.0.0 win10.ipv6.microsoft.com.nsatc.net
0.0.0.0 wns.notify.windows.com.akadns.net
0.0.0.0 wns.windows.com
0.0.0.0 www.bing.com
0.0.0.0 www.go.microsoft.akadns.net
#0.0.0.0 fe2.update.microsoft.com.akadns.net # MICROSOFT UPDATE - UNCOMMENT TO BLOCK
#0.0.0.0 fe2.update.microsoft.com.nsatc.net  # MICROSOFT UPDATE - UNCOMMENT TO BLOCK
#0.0.0.0 a767.dspw65.akamai.net              # MICROSOFT UPDATE - UNCOMMENT TO BLOCK
#0.0.0.0 sls.update.microsoft.com.akadns.net # MICROSOFT UPDATE - UNCOMMENT TO BLOCK
#0.0.0.0 ui.skype.com                        # MICROSOFT SKYPE - UNCOMMENT TO BLOCK
#0.0.0.0 pricelist.skype.com                 # MICROSOFT SKYPE - UNCOMMENT TO BLOCK
#0.0.0.0 apps.skype.com                      # MICROSOFT SKYPE - UNCOMMENT TO BLOCK
I have previously looked at that but does that actually solve the problem though? Read ryzhov_al post below
Please refer to this how-to on asuswrt-merlin releases newer then 378.55. Solution below is for 378.55 version and older.
Some guides offers to block unwanted sites via hosts file, but it's not working (in some cases) with Windows 10, which can detect DNS resolution is changed by user and use hardcoded IP addresses. So, it's better to resolve DNS names right and block traffic to this sites later.
My solution includes two independent parts:
  • creating set of unwanted IPs with ipset and block it with iptables. It's a part from firmware.
  • adding new unwanted IPs with ipset-dns. This is part from Entware.
That works by using NCSI as a workaround which you can disable according to the link provided and it's, if we trust MS, only for detecting your network status so the network icon can tell us when we're connected which I'm personally not concerned about. Of course, I haven't done any comprehensive testing of it as I just mostly wanted the malware protection.
V14 of my fork picked up ipset support, so as far as the quote, V14 and newer is the equivalent of 378.55 and newer.
