How to Dynamically Ban Malicious IP's using IPSet (Martineau version)
When I ran the "Grep" it produce the number 31303.
It is the 74k that my question is referring about.
<sigh>
What is the value reported by the iptables command output?
Did you run the other command as per the referenced post?
iptables --line -nvL INPUT | grep -E "set.*Blacklist|^num"
No! I didn't see it. Thanks Jack as usual.
Output of that is :
admin@RT-AC3100-0000:/jffs/scripts# iptables --line -nvL INPUT | grep -E "set.*Blacklist|^num"
num pkts bytes target prot opt in out source destination
9 37 2143 DROP all -- * * 0.0.0.0/0 0.0.0.0/0 match-set Blacklist src
I'm not sure how to interpret that though.
Output of that is :
That's only showing 37 packets, hm, try
iptables --line -nvL FORWARD | grep -E "set.*Blacklist|^num"
admin@RT-AC3100-0000:/jffs/scripts# iptables --line -nvL FORWARD | grep -E "set.*Blacklist|^num"
56 0 0 XHits all -- eth0 * 0.0.0.0/0 0.0.0.0/0 match-set Blacklist src
Hm, that's not verifying either. Have you recently rebooted between the 71k figure and now?
Hi
Thanks for your scripts !
I can find IPSET_Block v3.05 with HackerPorts v2.03, but apparently they are not the latest versions, i can't find v4.X with V2.06 or more. Can you provide links or update first post ?
Hi All,
Have the Asus RT-AC87U with Firmware:380.68_4
Script version :
(IPSET_Block.sh): 20974 v3.04 © 2016-2017 Martineau, Dynamic IPSET Blacklist banning request.....
Type: hash:ip
Revision: 4
Header: family inet hashsize 1024 maxelem 65536 timeout 604800
Size in memory: 4092
References: 0
Number of entries: 75
iptables: No chain/target/match by that name.
Syslog 'Block =' messages enabled
Summary Blacklist: 0 Successful blocks! ( 75 IPs currently banned - 0 added since: Oct 8 19:11 ), Entries auto-expire after 168:00:00 hrs
But it's writing nothing to my iptables, when i list them it is showing no banned ip's.
Do i need the new beta version to get it running ?
Hi. Please, how can I add 162.x.0.0/16 range to whitelist? Thank you in advance.
nslookup: can't resolve '162.x.0.0/16'
Hi
You can set whitelist when it's already started (with sh /jffs/scripts/IPSET_Block.sh init reset nolog for example) with :
sh /jffs/scripts/IPSET_Block.sh unban 162.x.0.0/16 whitelist (just replace x with your value)
./IPSET_Block.sh init
(IPSET_Block.sh): 31870 v3.05 © 2016-2017 Martineau, Dynamic IPSET Blacklist banning request.....
(IPSET_Block.sh): 31870 IPSET restore from '/tmp/mnt/RouterDrive/IPSET/IPSET_Block.config' starting.....
ipset v6.32: The set with the given name does not exist
iptables v1.4.15: Set Blacklist doesn't exist.
Try `iptables -h' or 'iptables --help' for more information.
(IPSET_Block.sh): 31870 Dynamic IPSET Blacklist banning enabled.
Summary Blacklist: 0 Successful blocks! ( 0 IPs currently banned - 0 added )
(HackerPorts.sh): 32021 v2.03 Hacker Port attacks Report.....
***ERROR IPSET Blacklist does not exist! - Please run 'IPSET_Block.sh init'
Please help using v3.05 and v2.03 of HackerPorts. I could not find the latest version after going through everything in threads.
Please, do you know if HackerPorts works well with Cloudflare?
Thank you!
So I suggest you create it as /jffs/scripts/IPSET_Block.sh, and as per the help info documented in the script, you will need to update firewall-start and init-start accordingly.
I followed these steps:
Create the ipset_block.sh.
"chmod +x" the script.
Edit the firewall-start, adding this line:
"sh /jffs/scripts/firewall start hackerports=/jffs/scripts/ipset_block.sh #hackerports" (Underneath the Skynet line)
Edit the init-start, adding this line:
"/jffs/scripts/ipset_block.sh init-start"
Then executed init-start: "sh init-start".
Now, this resulted in the following to appear:
(ipset_block.sh): 23088 v3.05 © 2016-2017 Martineau, Dynamic IPSET Blacklist banning request.....
I assume I missed something?
I'm running Merlin 384.8_2, with Skynet, Stubby and Deversion. On a RT-AC5300.
Thanks in advance!
Thanks in advance!
Skynet supercedes a lot of this script - you don't need both.
I thought so, but I'm not sure if Skynet starts blocking IP's (be it for a week) when they start making attempts at accessing multiple ports.
I'm not sure on the ins and outs - I think it used to, but it was discontinued as it caused more problems than it solved. @Adamm would be the one to ask :)
