Hi all. I have Skynet/Diversion installed and I have previously blacklisted around 11 or so domains associated with LG WebOS TV ads. For backstory I needed to block these domains to stop the TV from checking for Software updates and notifying me, because I rooted the TV. I wasn't actually getting ads on the TV.
I need to diagnose which of those domains I added blocks apple airplay on my local network, or blocks the TV from being able to detect it's connected to a network. The networking works, apps like netflix and other streaming apps still work, but the TV settings show it's not connected to a network. I assume the OS uses a connection to an LG domain to check connectivity. This has subsequently blocked Apple Airplay because it says the TV is not connected to a network. Samsung SmartShare still works lol.
I can't remember if I blocked the domains in Skynet or Diversion, and I can't find an easy way to search for domains that I have blocked previously. Are the domains stored in a file somewhere? I have tried the search function in Skynet and had no luck.
I need to go through one by one to see which of the domains I need to remove or whitelist. Should I just whitelist each domain one by one in skynet and test? A whitelist will override a blacklist (I think). But then how will I remove the domain from the whitelist if I can't find them. I don't understand if I would use the "unban/ban" options in the skynet menu, or the whitelist menu. I must have used the "ban" option to block the domains, as I don't see a "blacklist" option other than the "malware blacklist" option.
