RT-AX88U running Merlin version 3004.388.7
Installed Skynet using amtm
Router Model; RT-AX88U
Skynet Version; v7.5.9 (17/04/2024) (8bafa9c0ff41295c24a7871a8ad416b2)
iptables v1.4.15 - (vlan300 @ 192.168.1.1)
ipset v7.6, protocol version: 7
IP Address; (--------------) - (/)
FW Version; 388.7_0 (Apr 26 2024) (4.1.51)
Install Dir; /tmp/mnt/16GB-amtm/skynet (12.0G / 14.8G Space Available)
SWAP File; /tmp/mnt/16GB-amtm/myswap.swp (2.0G)
Using amtm. The debug test info shows that 18/18 tests successful (logging is enabled)
[#] 40447 IPs (+0) -- 2838 Ranges Banned (+0) || 7367 Inbound -- 420 Outbound Connections Blocked! [debug] [7s]
So Skynet appears to be installed and is running. However, when I open the SkyNet tab in Merlin I see the following
Skynet Statistics
Monitoring From To
Log Size - (0B
No Data to display.
Also in amtm. Running Open Skynet. Menu option 13 (stats). [1],[1],[1] It says "no logging detected, give this time to generate". But the SkyNet has been running for two days now.
I request some help. I have been trying to get it to work for 5 days now, and performed multiple installations. Logging is enabled, but it seems not to be logging, hence in Merlin nothing is ever displayed. What can I do to debug this?
SORRY! I cannot find a way to delete this post. But I have found the fix in another thread. I had to change the Merlin Log to Notice + Debug, now SkyNet works
. NOTE. I had never used the Log and have never changed the default settings. So suggest that this necessary info be included somewhere in the SkyNet installation check. Anyway, after 5 days of trying, I'm very happy to have found the solution. Thanks!
Skynet Statistics
Monitoring From To
Log Size - (0B
No Data to display.
