How to find free space on connected USB flash drive?
JoeSchmoe007
I have USB flash drive connected to RT-N66U. It is used only to save traffic history. I don't have any AI Cloud or USB applications active.
How to find free space on connected USB flash drive? FWIW I now run Merlin's 374.40 firmware.
I'll answer my own question (should've tried harder before I asked :D):
  1. Enable telnet access via Administration/System/Miscellaneous in web interface.
  2. Telnet into the router and use the same credentials as to login to web interface.
  3. Run "df" command.
  4. Disable telnet access.
Or, simply log on your router's webui, and click on the USB disk. It will display the total space, and remaining space.
