how to make asus router automatically reboot every day?
Well I gave it a try and it doesn't reboot every 4 hours.
This was the log:
May 6 13:53:01 crond[463]: user admin: parse error at /4
I used this command: /usr/sbin/cru a ScheduledReboot "0 /4 * * * reboot"
I guess it's a no go but then again I don't know any better.
Well I gave it a shot before going aways for the weekend. It worked well for a day but then I lost all traffic that went through the router via WiFi. It was very strange. In the end I had to factory reset the router and start back from scratch. I guess I may just use the daily reboot built into the firmware for now until I can do more tests.
what if I just want to reboot once a week.. let's say every Sunday at 6am?
What code would that be?
EDIT...
would this work?
#!/bin/sh
cru a ScheduledReboot "* 6 * * 0 /sbin/reboot"
EDIT...
would this work?
#!/bin/sh
in case you dont know, you can set up reboot schedule via ui
Will the reboot schedule in the GUI also reboot the mesh unit?
