how-to nslookup hostname to append domain
Is this what you mean?
C:\Users\Colin>nslookup zen
Server:  router.asus.com
Address:  192.168.1.1
Address:  192.168.1.238
that is interesting .. i have to append a '.' to get a result ..
C:\Users\walter>nslookup PC0CUGP9
*** router.asus.com can't find PC0CUGP9: Non-existent domain
C:\Users\walter>nslookup PC0CUGP9.
Address: 192.168.1.5
That's usually because the "Connection-specific DNS Suffix" for the network adaptor is not set.
EDIT: Or your router doesn't have a domain name set in its configuration. So the domain suffix is in fact a null string, "".
I ran set debug on my hostname PC0CUGP9 (windows 7 dhcp client) ..
PC0CUGP9.Org.companyname.local
Also forgot to mention that this is my company laptop that is on the domain at work but I use it at home on my network Looks like it is appending the Org.companyname.local domain to my nslookup ...
going to put my home box on dhcp and see if I get a different result...
after putting the MacBook on dhcp it is appending the domain now when doing nslookup hostname
for example: nslookup macbook1 -> macbook1.private.net
..my work pc on my dhcp network ..will not append the domain due to the company adding the machine to its own domain ..
nslookup m1 on my macbook terminal.. it still not appending the domain.. results below -
Flush the cache on the Macbook when making changes...
sudo dscacheutil -flushcache; sudo killall -HUP mDNSResponder
