How to restrict VPN accessibility to main WiFi network
calculon
Current setup:
Router is gateway & AP
VPN is enabled to connect to router in another state
Guest Network 1 is active
I recently enabled a WiFi network for my roommates so they could hop on without opening up my main network to them.
However, I quickly found that when doing so, the VPN link I have active allows them to access this as well.
They are setup on a guest network SSID with intranet access disabled.
Is this by design that VPN access is accessible to Guest SSIDs?
Is there a way to limit this so that the VPN access is available ONLY to the main SSID or non-guest networks?
If you need more info, please ask.
