Hi all,
i would like to know if there is some way how to setup the WAN port speed to 1G Full Duplex permanently. The port is set to autonegotiation (found via SSH). I was able to figure out how to set the port to 1G Full Duplex but the settings disappeared after while and i would like to change the config somewhere via SSH to make it permanent. Does anybody knows how to do it?
Thank you.
Thank you.
