How to set up IPv6 on AX88U PRO
Yes, the firewall is on
Ask the HE certified "dude" above if this firewall on your cascaded router is even doing anything in Passthrough mode, please. He probably knows... with more private double NAT and IPv6 enabled ideas. What you did - created a second door to/from your network in/out. Now you have to secure this IPv6 door the same way IPv4 is secured. If you use public VPNs - most will disable IPv6 to prevent leaks. Don't be surprised. Have fun with HE.
Yes, I've noticed most VPNs disable IPv6.
The firewall in ISP ONT/router seems to be ON as well (but can't be changed):
