Hi John,You are trying to load an ovpn file for a windows client. Search your providers site for a linux file or one targeted towards routers.
Thanks Mike,Router WAN 192.168.1.5
Default gateway 192.168.1.1 ( The number you enter to access the Dlink.)
Subnet 255.255.255.0 (same as what the Dlink Ethernet is.)
DNS Servers will be what you have on the Dlink
That should work
now that everything is working, reboot everything and then try to set it up. If that doesn't work i would try there support. maybe they can walk you though it.Thanks Mike,
That solved the issue of getting the router to operate in the DLINK DMZ. Internet now connects with all those settings, however I still have issues with the Router giving me "Error - check configuration!" Messages when I upload the ovpn file to the router![]()
Did you try setting the VPN Client up using the Tomato router setup?Waiting on there support at the moment. Tried repowering it all and restarting everything but all to no avail.
Thanks for all your help and suggestions though.
Thanks Mike,
.... IPv6 was turned off. Turned it on and bingo, VPN connects and works
Welcome To SNBForums
