How to wring out problem: AC68U mesh node drops
kentek
I have 2 RT-AC68U in a mesh set up. The Primary router is connected to FIOS modem via Ethernet. Both Asus routers have V 385.15 firmware. Performance is very good. Only issue is that the Mesh Node goes to sleep every once in a while requiring either a 3-4 minute wait until is comes back or a node reboot. The Mesh node is on WIFI and about 80 feet away from Primary.
The Primary-Router never seems to have a problem. Not a lot of traffic as I am only user. Drops sometime while on computer or using Roku for streaming.
Looking for something obvious but don't see anything.
Log errors all have a reference to DHCP. Here is today's Error log> I don't understand it:
Apr 19 00:23:26 syslog: WLCEVENTD wlceventd_proc_event(420): eth1: Auth D8:31:34:86:EF:42, status: 0, reason: d11 RC reserved (0)
Apr 19 00:23:26 syslog: WLCEVENTD wlceventd_proc_event(449): eth1: Assoc D8:31:34:86:EF:42, status: 0, reason: d11 RC reserved (0)
Apr 19 00:23:26 dnsmasq-dhcp[226]: DHCPREQUEST(br0) 192.168.2.39 d8:31:34:86:ef:42
Apr 19 00:23:26 dnsmasq-dhcp[226]: DHCPACK(br0) 192.168.2.39 d8:31:34:86:ef:42
Apr 19 00:23:28 syslog: WLCEVENTD wlceventd_proc_event(386): eth1: Deauth_ind D8:31:34:86:EF:42, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Apr 19 00:23:28 syslog: WLCEVENTD wlceventd_proc_event(386): eth1: Deauth_ind D8:31:34:86:EF:42, status: 0, reason: Class 3 frame received from nonassociated station (7)
Apr 19 00:23:29 dnsmasq-dhcp[226]: DHCPREQUEST(br0) 192.168.2.39 d8:31:34:86:ef:42
Apr 19 00:23:29 dnsmasq-dhcp[226]: DHCPACK(br0) 192.168.2.39 d8:31:34:86:ef:42
Apr 19 05:20:14 dnsmasq-dhcp[226]: DHCPDISCOVER(br0) 68:9c:70:b8:e7:06
Apr 19 05:20:14 dnsmasq-dhcp[226]: DHCPOFFER(br0) 192.168.2.181 68:9c:70:b8:e7:06
Apr 19 05:20:15 dnsmasq-dhcp[226]: DHCPREQUEST(br0) 192.168.2.181 68:9c:70:b8:e7:06
Apr 19 05:20:15 dnsmasq-dhcp[226]: DHCPACK(br0) 192.168.2.181 68:9c:70:b8:e7:06 kenteks-iPhone
Apr 19 05:37:37 dnsmasq-dhcp[226]: DHCPREQUEST(br0) 192.168.2.39 d8:31:34:86:ef:42
Apr 19 05:37:37 dnsmasq-dhcp[226]: DHCPACK(br0) 192.168.2.39 d8:31:34:86:ef:42
Apr 19 07:02:50 dnsmasq-dhcp[226]: DHCPDISCOVER(br0) d4:4d:a4:c2:ce:01
Apr 19 07:02:50 dnsmasq-dhcp[226]: DHCPOFFER(br0) 192.168.2.57 d4:4d:a4:c2:ce:01
Apr 19 07:02:50 dnsmasq-dhcp[226]: DHCPREQUEST(br0) 192.168.2.57 d4:4d:a4:c2:ce:01
Apr 19 07:02:50 dnsmasq-dhcp[226]: DHCPACK(br0) 192.168.2.57 d4:4d:a4:c2:ce:01 Galaxy-Note10
Apr 19 07:13:53 dnsmasq-dhcp[226]: DHCPREQUEST(br0) 192.168.2.138 2c:aa:8e:81:75:f3
Apr 19 07:13:53 dnsmasq-dhcp[226]: DHCPACK(br0) 192.168.2.138 2c:aa:8e:81:75:f3
Apr 19 08:08:03 rc_service: httpd 236:notify_rc restart_logger
Apr 19 08:08:03 syslogd exiting
Apr 19 08:08:04 syslogd started: BusyBox v1.25.1
Apr 19 08:08:04 kernel: klogd started: BusyBox v1.25.1 (2020-02-08 13:38:20 EST)
Apr 19 08:09:52 rc_service: httpd 236:notify_rc restart_wlcscan
Apr 19 08:16:00 dnsmasq-dhcp[226]: DHCPREQUEST(br0) 192.168.2.118 40:b0:76:ae:fe:78
Apr 19 08:16:00 dnsmasq-dhcp[226]: DHCPACK(br0) 192.168.2.118 40:b0:76:ae:fe:78 RT-AC68U-FE78
Apr 19 08:22:04 kernel: nvram: consolidating space!
Inspect the two wireless backhaul entries in the Wireless Log. 80' may be too far/weak for 68Us. You could move them to say 40' to see if the problem stops.
OE
No, I have ASUSMerlin installed on both devices: 384.15. I have now updated to 384.16. Both routers rebooted.
Thanks for letting me know of newer version. We'll see if it make a difference.
The issue could be the crappy FIOS modem/router on the other end.
ken
