HTTPS web access from WAN
colecaz
In accessing my RT-AC66U running Merlin 378.52 via Https I get a warning from Chrome about an unverified certificate. After I agree I know it's dangerous and go on to access the router I get the Https indication at the beginning of the router URL and the logon popup comes up normally. However, after logging on the Https indication has a red line through it and a unlocked padlock appears in front of it and I am able to configure the router. This happens both locally using the local IP address and via DDNS using DynDns or No-IP.
I have selected Https access on the Admin-System page and left the port at the default 8443.
Is this normal or have I missed a setup step to avoid the warnings and get a solid, secure, access session?
It's a self signed certificate. This is to be expected and perfectly normal. Your access is still secure as long as you know the machine or device you're accessing is yours.
So https, being encrypted, protects you from eavesdroppers or man-in-the-middle attacks, but it doesn't stop someone else logging in. But as long as your username/password pair is not the default one, or admin/monkey etc, i.e. they are a strong, not-obvious combination, you'll be quite safe: you know how time consuming it is just to get access with the correct pair, and how frustrating and time consuming when you mis-type the credentials, and that's when you know the username and password.
Certificates, self signed or not do not protect you when you use the default username and a password as strong as 12345678.
Just saying.
Just saying.
Indeed, yes, it does need to be emphasised, so people understand the limitations. Until I knew better, I assumed https access was the ultimate solution. Now that I know better I realise there is no ultimate solution, other than never connecting to anything. (So I don't allow any WAN access, other than by SSH or OpenVPN.)
A wise decision. Unless you really need it, better leave it off.
As I understand the replies above, the only part of remote access that is encoded is the login process and the username/password. Is this correct? I was expecting that the entire session would be protected and the indication on the address line of the browser would continue to show https valid instead of changing to indicate a problem. When I access my credit card account on line the https:// prefix to the URL stays green and the lock symbol stays locked throughout the session and I was expecting the same when accessing the router via https.
And I have changed the username/password from the defaults. That's among the first things I do in any new setup.
@colecaz What I was saying is: The user/pass on any website is the most vulnerable part. While on https your communication is encrypted at all times. The security warning you get for a self signed certificate is because that certificate cannot be verified by a trusted third party such as VeriSign.
@lonely Thanks. Being encoded but alerted to an untrusted certificate makes the indication make sense now.
