Bad2theBone
I have both a RT-N66U & RT-AC66U and both have this problem I am running stock factory current firmware (had been on the N66U - AC66U is replacing it) and when I go to Administration->System page I find in yellow the above message under the NTP Server information. I have tried changing the server pool from the global pool to northamerica pool and is now set to us.pool.ntp.org and still get the message. On the RT-AC66U I also get "* Remind: The System time zone is different from your locale setting." in the timezone settings part for the ntp config. This stays on whether I use manual or automatic day light savings setting. I also have a EA-N66 that I use as a repeator that gives me the same warning for ntp synchronization.
As a result fo this my logs all show the wrong date & time. I would like to get this working correctly. Is there something else I should be doing that I've missed or forgotten?
